I recently needed to demonstrate how two micro-frontend applications (aka Script Applications) could communicate with each other when deployed on the same DX page.
One micro-frontend was written in React and the other in Angular and I decided to use the CustomEvent constructor to demonstrate this.
The Angular app retrieved a set of items by calling a REST API then displayed the response in a table format. Selecting an item in the table created the CustomEvent, passing the selected object as a parameter. Here’s a code snippet:
// Function to dispatch a custom event with the selected item
select(item: any): void {
// Create and dispatch a custom event named 'selected-item-event'
// The event carries the selected item as a JSON string in the 'detail' object
window.dispatchEvent(
new CustomEvent('selected-item-event', {
detail: {
message: JSON.stringify(item), // Serialize the item to a JSON string
The React app listened for this CustomEvent and retrieved data using information in the passed object to call a different REST API. The resulting response was displayed in a card format showing the item details and a map. Here’s a code snippet:
import { useEffect } from 'react';
useEffect(() => {
// Event handler for the custom 'selected-item-event'
const handleSelectedItemEvent = (e) => {
// Safely parse the JSON message from the event's detail object
// and pass the resulting object to fetchItemData
fetchItemData(JSON.parse(e.detail.message));
// Register the event listener when the component mounts
window.addEventListener('selected-item-event', handleSelectedItemEvent);
// Cleanup: remove the event listener when the component unmounts
return () => {
window.removeEventListener('selected-item-event', handleSelectedItemEvent);
}, []); // Empty dependency array ensures this effect runs only once (on mount)
Hope this is helpful.
