Subject: EasySync Pro 4.2.4 conduit not installed
Initially burried this a down in the thread, moving it out:
I believe I have the same issue. New ThinkPad, Notes 7.0, Hotsync 4.1.0 EasySyncPro 4.2.4, Treo 600, Palm 5.2.
Installed HotSync, installed EasySync via ISSI. HotSync works fine. EasySync, when I click Synchronize says HotSync can not be found. Have tried “Force Full Synchronize”, no luck.
Only have Application1 and Application2 in the registry.
C:\Program Files\Common Files\XCPCSync.OEM\Lotus.211.101\Translators\PalmOS\rsCondut.dll version 4.24.6868.0
Assume it’s in the correct place.
I don’t see how to tell HotSync to use EasySync, and EasySync can not find HotSync.
I turned on logging, 2 debug. Found the log:
EasySync Pro Sync Log
Sync started at 12:11:24 AM on 10/25/06
Version 4.24.6868 (1033)
Product ID: 211-101
User: IBM_USER
Company: IBM
Data Path: C:\Documents and Settings\Administrator\Application Data\XCPCSync.OEM\Lotus.211.101
18:34 CRSyncUtil::GetTranslator : Path ‘C:\Program Files\Common Files\XCPCSync.OEM\Lotus.211.101\Translators\PalmOS;’ added to environment variable while loading translator ‘PalmOS’
18:34 Translator ‘PalmOS’ with version ‘1.0’ loaded successfully from ‘C:\Program Files\Common Files\XCPCSync.OEM\Lotus.211.101\Translators\PalmOS\PalmOS.dll’
18:34 Module Version: 4.24.6868
18:34 Enter - PalmOS : InitTranslatorEx
18:34 CRSyncUtil::GetTranslator : Translator successfully initialized for translator ‘PalmOS’
18:34 CRSyncUtil::GetTranslator : Loaded, initialized and recorded translator ‘PalmOS’ successfully
18:34 Entry: GetMachineInfo
18:34 Enter CPilotApiWnd::InstallConduit
18:34 CPalmCondMgr::CPalmCondMgr() : LoadLibrary() API failed for module \CondMgr.dll
18:34 CPalmCondMgr::CPalmCondMgr() : System error message - The specified module could not be found.
18:34 Enter UIDisplayMessage(Unable to find HotSync. Please restart Hotsync. If this doesn’t work, please reinstall HotSync and try again., Palm OS Device HotSync, 0 16)
18:34 Exit UIDisplayMessage(Unable to find HotSync. Please restart Hotsync. If this doesn’t work, please reinstall HotSync and try again., Palm OS Device HotSync, 0 16) returning 1
18:34 ERROR: PALM_OS GetMachineInfo connection failed
18:34 CRSyncUtil::GetMachineInfo : GetMachineInfo() API failed in translator ‘PalmOS’. Error message : Unable to connect to device.
18:35 EXIT CXtndPCuiApp::OnSync()
18:35 Loading profiles
18:35 Finished loading profiles
18:35 Loading contract list
18:35 Initializing WebWindow
18:35 Done initializing WebWindow
18:35 Initialization Complete
21:22 Enter CRSyncUtil::Close
21:22 Enter - PalmOS : UninitTranslator
21:22 Exit CRSyncUtil::Close
21:22 Closing sync engine
21:22
21:22
21:22 Sync completed at 12:21:22 AM on 10/25/06
What’s interesting is it says it can’t find condmgr.dll. Mine is in c:\Program Files\PalmOne and is version 4.0.1.0
I added that to the path, still fails.
