WSDL Validation Problem - soapenc
Im exposing a ws in domino 6.5 and therefore do not have capabilities of 7. I have to create WSDL manually in Eclipse and Im having problems with declaring Arrays and inparticular the soapenc namespace…
Heres the complete WSDL below…
<?xml version="1.0" encoding="UTF-8"?>
<definitions name=“calendarService”
xmlns= "http://schemas.xmlsoap.org/wsdl/"
xmlns:soapenc=“http://schemas.xmlsoap.org/soap/encoding/” targetNamespace= “http://eagle.nottscc.gov.uk/dev/mandip/calendarTest.nsf/calendarService.wsdl
xmlns:soap= "http://schemas.xmlsoap.org/wsdl/soap/"
xmlns:tns= "http://eagle.nottscc.gov.uk/dev/mandip/calendarTest.nsf/calendarService.wsdl"
xmlns:xsd= "http://www.w3.org/2001/XMLSchema"
xmlns:wsdl="http://schemas.xmlsoap.org/wsdl/" >
<types>
    <xsd:schema
      	targetNamespace= "http://eagle.nottscc.gov.uk/dev/mandip/calendarTest.nsf/calendarService.wsdl"
      	xmlns="http://www.w3.org/2001/XMLSchema">
    <xsd:simpleType name="EntryType">
    	<xsd:restriction base="string">
    		<xsd:enumeration value="Meeting"></xsd:enumeration>
    		<xsd:enumeration value="Event"></xsd:enumeration>
    		<xsd:enumeration value="Appointment"></xsd:enumeration>
    	</xsd:restriction>
    </xsd:simpleType>
    <xsd:complexType name="Credentials">
		<xsd:sequence>
			<xsd:element name="UID" type="xsd:string"/>
			<xsd:element name="password" type="xsd:string"/>
		</xsd:sequence>
	</xsd:complexType>
	<xsd:element name="DateAdded">
	<xsd:simpleType>
		<xsd:restriction base="xsd:gDay">
     		 <xsd:pattern value="[0-2][0-9]"/>
		</xsd:restriction>
		</xsd:simpleType>
	</xsd:element>
	<xsd:complexType name="CalendarRequest">
        <xsd:sequence>
			<xsd:element name="UID" type="xsd:string" maxOccurs="1" minOccurs="1" nillable="false" />
			<xsd:element name="password" type="xsd:string" maxOccurs="1" minOccurs="1" nillable="false" />
			<xsd:element name="targetMailFile" type="xsd:string" maxOccurs="1" minOccurs="1" nillable="false" />
			<xsd:element name="startDate" minOccurs="1"
				maxOccurs="1" nillable="false" type="xsd:date">
			</xsd:element>
			<xsd:element name="endDate" minOccurs="1" maxOccurs="1" type="xsd:date" nillable="false" />
			<xsd:element name="startTime" minOccurs="1" maxOccurs="1" type="xsd:time" nillable="false" />
			<xsd:element name="endTime" minOccurs="1" maxOccurs="1" type="xsd:time" nillable="false" />
			<xsd:element name="appointmentType" maxOccurs="1"
				minOccurs="1" type="xsd:string" />
			<element name="appontmentTypeNew" nillable="true"
				type="tns:EntryType" minOccurs="1" maxOccurs="1"/>
			<xsd:element name="subject" minOccurs="1" maxOccurs="1" type="xsd:string" nillable="false" />
		</xsd:sequence>
	</xsd:complexType>
	<xsd:complexType name="EditRequest">
		<xsd:sequence>
			<xsd:element name="UID" type="xsd:string" maxOccurs="1" minOccurs="1"/>
			<xsd:element name="password" type="xsd:string" maxOccurs="1" minOccurs="1"/>
			<xsd:element name="targetMailFile" type="xsd:string" maxOccurs="1" minOccurs="1"/>
			<xsd:element name="appointmentUNID" type="xsd:string" maxOccurs="1" minOccurs="1"/>
			<xsd:element name="startTime" type="xsd:time" maxOccurs="1" minOccurs="0"/>
			<xsd:element name="endTime" type="xsd:time" maxOccurs="1" minOccurs="0"/>
			<xsd:element name="subject" type="xsd:string" maxOccurs="1" minOccurs="0"/>
		</xsd:sequence>
	</xsd:complexType>
	 <xsd:complexType name="DeleteRequest">
		<xsd:sequence>
			<xsd:element name="startDate" type="xsd:date" maxOccurs="1" minOccurs="1"/>
			<xsd:element name="endDate" type="xsd:date" maxOccurs="1" minOccurs="1"/>
		</xsd:sequence>
	</xsd:complexType>
	<xsd:complexType name="RetrieveRequest">
		<xsd:sequence>
			<xsd:element name="targetDate" type="xsd:date" maxOccurs="1" minOccurs="1"/>
		</xsd:sequence>
	</xsd:complexType>
	<xsd:complexType name="RetrieveResults">
		<xsd:sequence>
			<xsd:element name="apptUNID" type="xsd:string"/>
			<xsd:element name="appointmentType" type="xsd:string"/>
			<xsd:element name="subject" type="xsd:string"/>
			<xsd:element name="startDateTime" type="xsd:date"/>
			<xsd:element name="endDateTime" type="xsd:date"/>
			<xsd:element name="startTime" type="xsd:time"/>
			<xsd:element name="endTime" type="xsd:time"/>
		</xsd:sequence>
	</xsd:complexType>
	<xsd:complexType name="RetrieveResultsArray">
		<xsd:complexContent>
			<xsd:restriction base="soapenc:Array" >
				<xsd:attribute ref="arrayType" wsdl:arrayType="tns:RetrieveResults[]" />
			</xsd:restriction>
	   </xsd:complexContent>
	</xsd:complexType>
 </xsd:schema>
</types>
<message name="createCalendarEntryRequest">
    <part name="createEntryRequest" type="tns:CalendarRequest"/>
</message>
<message name="createCalendarEntryResponse">
	<part name="success" type="xsd:boolean"/>
    <part name="apptUNID" type="xsd:string"/>
</message>
<message name="editCalendarEntryRequest">
    <part name="editEntryRequest" type="tns:EditRequest"/>
</message>
<message name="editCalendarEntryResponse">
    <part name="result" type="xsd:string"/>
</message>
<message name="deleteCalendarEntryRequest">
    <part name="deleteEntryRequest" type="tns:DeleteRequest"/>
</message>
<message name="deleteCalendarEntryResponse">
</message>
<message name="retrieveCalendarEntriesRequest">
    <part name="retrieveEntriesRequest" type="tns:RetrieveRequest"/>
</message>
<message name="retrieveCalendarEntriesResponse">
   <part name="retrieveEntriesResponse" type="tns:RetrieveResultsArray"/>
 <!-- <part name="result" type="xsd:string"/>-->
</message>
<portType name="calendarServicePort">
    <operation name="createCalendarEntry">
        <input message="tns:createCalendarEntryRequest"/>
        <output message="tns:createCalendarEntryResponse"/>
    </operation>
    <operation name="editCalendarEntry">
        <input message="tns:editCalendarEntryRequest"/>
        <output message="tns:editCalendarEntryResponse"/>
    </operation>
    <operation name="deleteCalendarEntry">
        <input message="tns:deleteCalendarEntryRequest"/>
        <output message="tns:deleteCalendarEntryResponse"/>
    </operation>
  <operation name="retrieveCalendarEntries">
        <input message="tns:retrieveCalendarEntriesRequest"/>
        <output message="tns:retrieveCalendarEntriesResponse"/>
    </operation>
</portType>
<binding name="calendarServiceBinding" type="tns:calendarServicePort">
    <soap:binding style="rpc" transport="http://schemas.xmlsoap.org/soap/http"/>
        <soap:operation
            soapAction="urn:createCalendarEntryAction"/>
        <input>
            <soap:body
                encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"
                namespace="urn:calendarService"
                use="encoded"/>
        </input>
        <output>
            <soap:body
                use="encoded"/>
        </output>
    </operation>
        <soap:operation
            soapAction="urn:editCalendarEntryAction"/>
        <input>
            <soap:body
                use="encoded"/>
        </input>
        <output>
            <soap:body
                use="encoded"/>
        </output>
    </operation>
    <soap:operation
            soapAction="urn:deleteCalendarEntryAction"/>
        <input>
            <soap:body
                use="encoded"/>
        </input>
        <output>
            <soap:body
                use="encoded"/>
        </output>
    </operation>
        <soap:operation
            soapAction="urn:retrieveCalendarEntryAction"/>
        <input>
            <soap:body
                use="encoded"/>
        </input>
        <output>
            <soap:body
                use="encoded"/>
        </output>
    </operation>
</binding>
<service name="calendarServiceService">
    <port name="calendarServicePort" binding="tns:calendarServiceBinding">
        <soap:address location="http://eagle.nottscc.gov.uk/dev/mandip/calendarTest.nsf/WebService"/>
    </port>
</service>
Ive been banging my head on this one for a while so any help would be great. Thanks.
