Works ID-Vault and Basic-Client?
Sorry, I found nothing inside the docu…
Works ID-Vault also with a 8.5 Basic Client by starting only the nlnotes.exe (Citrix environment)?
I set IDVAULT_RESYNC_INTERVAL=60 in the client notes.ini, but also after some hours I had no entry in my ID-Vault???
Is it possible to force the sending of the ID from the client side to the ID-Vault?
Uwe
Subject: Yes, ID vault is supported with the Notes Basic client
Can you attach log entries from log.nsf on both client and server? Vault transactions are found in the Security view.
