Word Automation using lotusscript
Using the code pasted i am outputting documents to MS Word, the problem I’m having is all the tables that list document budget information are sent to the bottom of the document rather than in line with the other information. So if i have twelve notes documents selected they are output to one word doc and there are twelve budget tables at the bottom, they should be with their respective document information, can anyone see the problem?
Sub Initialize
Dim workspace As New notesuiworkspace
Dim session As New notessession
Dim Db As notesDatabase
Dim collection As notesdocumentcollection
Dim doc As notesDocument, uidoc As notesuidocument
Dim uiview As notesuiview
Dim rtitem As Variant
Dim TestItem As notesitem
Dim wordapp As Variant
Dim vValue As Variant
Dim i As Integer, imgCounter As Integer
Dim pDescription As String
Dim sValidated As String
Dim ImgDoc As notesDocument
Dim ImgView As notesView
Dim ActivityView As notesView
Dim ActivityDc As NotesDocumentCollection, ActivityDoc As notesDocument
Set uiview = workspace.currentview
Set wordapp = createObject( “word.Application” )
wordapp.Visible = False
Set WordDocument = WordApp.Documents.Add()
TCounter = 0
Set collection = db.UnprocessedDocuments
For i = 1 To collection.count
TCounter = TCounter +1
Set Doc = collection.getnthdocument(i)
wordapp.Selection.Font.Size = 14
wordapp.Selection.Font.Name = “Helvetica”
wordApp.Selection.ParagraphFormat.Alignment = 0
wordapp.Selection.Font.ColorIndex = 1
wordapp.Selection.Font.Underline = True
wordapp.Selection.Font.Bold = True
wordapp.Selection.TypeText(doc.PrgTitle(0))
wordapp.Selection.TypeParagraph
wordapp.Selection.TypeText(doc.PrjTitle(0))
wordapp.Selection.Font.Size = 12
wordapp.Selection.TypeText(“Brief Description:”)
wordapp.Selection.Font.Bold =False
wordapp.Selection.Font.Underline = False
wordapp.Selection.TypeText(" " & doc.PrjDesc(0))
wordapp.Selection.TypeText(“Detailed Description:”)
wordapp.Selection.TypeText(" " & doc.DetailedDesc(0))
wordapp.Selection.Font.Bold = False
wordapp.Selection.TypeText(“Financial Table”)
wordapp.Selection.Font.Size = 10
Set range = WordApp.Selection.Range
Set table = WordDocument.Tables.Add(range,6,5)
table.Cell(1, 1).Range.InsertAfter (“”)
table.Cell(1, 2).Range.InsertAfter (“Internal”)
table.Cell(1, 3).Range.InsertAfter (“External”)
table.Cell(1, 4).Range.InsertAfter (“Project Budget”)
table.Cell(1, 5).Range.InsertAfter (“Variance”)
table.Cell(2, 1).Range.InsertAfter (“O&M”)
table.Cell(3, 1).Range.InsertAfter (“Salary”)
table.Cell(4, 1).Range.InsertAfter (“FTE(Day)”)
table.Cell(5, 1).Range.InsertAfter (“G&C”)
table.Cell(2, 2).Range.InsertAfter (Format(doc.Int_OM(0),“Currency”))
table.Cell(3, 2).Range.InsertAfter (Format(doc.Int_Sal(0),“Currency”))
table.Cell(4, 2).Range.InsertAfter (doc.Int_FTE(0))
table.Cell(5, 2).Range.InsertAfter (Format(doc.Int_GC(0),“Currency”))
table.Cell(2, 3).Range.InsertAfter (Format(doc.Ext_OM(0),“Currency”))
table.Cell(3, 3).Range.InsertAfter (Format(doc.Ext_Sal(0),“Currency”))
table.Cell(4, 3).Range.InsertAfter (doc.Ext_FTE(0))
table.Cell(5, 3).Range.InsertAfter (Format(doc.Ext_GC(0),“Currency”))
table.Cell(2, 4).Range.InsertAfter (Format(doc.OM_Budget(0),“Currency”))
table.Cell(3, 4).Range.InsertAfter (Format(doc.Sal_Budget(0),“Currency”))
table.Cell(4, 4).Range.InsertAfter (doc.FTE_Budget(0))
table.Cell(5, 4).Range.InsertAfter (Format(doc.GC_Budget(0),“Currency”))
table.Cell(2, 5).Range.InsertAfter (“N/A”)
table.Cell(3, 5).Range.InsertAfter (“N/A”)
table.Cell(4, 5).Range.InsertAfter (Format(doc.FTE_Variance(0), “Currency”))
table.Cell(5, 5).Range.InsertAfter (“N/A”)
'WordApp.Selection.MoveDown
wordApp.Selection.Insertbreak
Set ActivityView = db.getView(“ActivityLookup”)
Set ActivityDc = ActivityView.getAlldocumentsbykey(doc.universalid)
If ActivityDc.count > 0 Then
wordapp.Selection.TypeText(“Activities”)
For a = 1 To ActivityDc.count
Set ActivityDoc = ActivityDc.getnthdocument(a)
wordapp.Selection.TypeText(" Activity:")
wordapp.Selection.TypeText(" " & ActivityDoc.Activity1(0))
wordapp.Selection.TypeText(“Deliverable:”)
wordapp.Selection.TypeText(" " & ActivityDoc.Deliverable1(0))
wordapp.Selection.TypeText(“Rational / Defence:”)
wordapp.Selection.TypeText( " " & ActivityDoc.Rational1(0))
wordapp.Selection.TypeText(“Approval Status:”)
wordapp.Selection.TypeText(" " & ActivityDoc.APStatus(0))
wordapp.Selection.TypeText(“Activity Status:”)
wordapp.Selection.TypeText(" " & ActivityDoc.Status(0))
wordapp.Selection.TypeText(“Target Date:”)
If Not ActivityDoc.Date1(0) = “” Then
wordapp.Selection.TypeText(" " & Str(ActivityDoc.Date1(0)))
wordapp.Selection.TypeText(“FTE (Day):”)
wordapp.Selection.TypeText(" " & Str(ActivityDoc.FTE(0)))
wordapp.Selection.TypeText(“Budget:”)
If Isnumeric(ActivityDoc.Budget(0)) Then
wordapp.Selection.TypeText(" " & Str(ActivityDoc.Budget(0)))
wordapp.Selection.TypeText(“Expenditures:”)
wordapp.Selection.TypeText(" " & Str(ActivityDoc.Allocated(0)))
wordapp.Selection.TypeText(“Variance:”)
wordapp.Selection.TypeText(" " & Str(ActivityDoc.Varian(0)))
Next
Next i
wordapp.Visible = True
