Wireless Palm and iNotes Web Access
Hi to all, I’m trying to acces my web mail with a wireless palm. What do I need to configure to be able to get this thing to work
I’m running domino V 6.0.1 CF1 on an iSeries
Thanks for your help
Regards
Danick Vanier
Subject: You could use Extended Systems xtnded connect server, which supports iNotes for PDAs.
Subject: RE: You could use Extended Systems xtnded connect server, which supports iNotes for PDAs.
Not sure you’re going to find any server-based sync products that work on the iSeries.
There are quite a number of good products which will allow you to sync, but I believe they all require a Windows environment.
I’ve posted this list before (thanks to copy-and-paste!), but I’d suggest you check out:
Cadenza mNotes (http://www.commontime.com)
Pylon Pro (http://www.avantgo.com)
Intellisync (http://www.pumatech.com)
XTND Connect (http://www.extendedsystems.com)
All of these sync products have server-based options, which is what you really want if you want to sync via the PDA’s internet capabilities.
Hope that helps …
  • Rob
Subject: Wireless Palm and iNotes Web Access
What kind of wireless palm are you using?
Remember that iWA is only compatible with Internet Explorer on the Windows platform…
Check out http://www.mail-e-on-air.com - there is a free “trial” that you can use. I use this and it works pretty well for text-only access.
