Prior to 11, I never had a problem letting the Notes client stay logged in to a server.
It runs an IMAP process so it needs to stay up 24x7.
ONLY the R11 clients stop at exactly 72 hours.
Notes shut down. Period, cleanly too as far as I can see.
I have to go open Notes again.
Nothing else on the machine is affected.
Support was not very helpful at all.
Hello Keith!
Could you share the Case number where you working with Support Team?
Regards!
Rodrigo de San Vicente
Staff Software Engineer
Collaborative Workflow Platform
Think it was this one, CS0139915
Hello Keith!
Did you receive the KB below:
> Notes client crash when workspace\logs folder gets too big
https://support.hcltechsw.com/csm?id=kb_article&sysparm_article=KB0077861
I suggest you to change Java maximum heap size then check if the behaviour changes.
Regards!
Thanks but that is what they asked me to do as well, did not change anything.
What value did you set?
Regards!
As it said in the technote:
vmarg.Xmx=-Xmx512m
vmarg.Xms=-Xms512m
vmarg.Xmca=-Xmca512k
vmarg.Xss=-Xss1m
Be careful with 1024MB Java setting
https://www.panagenda.com/2020/08/the-out-of-memory-mystery-in-notes-11/
Thank you for the link! It clearly documents why the old strategy for providing more merory to the JVM no longer works in Notes 11, because of missing compiler flags in the currently employed JVM. Hopefully the fix will be available soon.
Well that didn't change anything, 72 hours on the dot, stops. What the heck is going on?
Any clues available in the console.log file in the IBM_TECHNICAL_SUPPORT?
If none is produced, check the notes.ini for Console_Log_Enabled=1
Also, if no useful information is present, you can use Console_LogLevel to increrase the level:
0 - No information displayed.
1 - Only errors are displayed.
2 - Summary progress information is displayed.
3 - Detailed progress information is displayed.
4 - Full trace information is displayed.
Default is 2.
You may need to use other notes.ini Console log settings to control creation and handling of console log files. I know it says Domino console log in the documentation a lot, but in my understanding the Notes client shares a lot of code with Domino, and thus also shares a lot of notes.ini settings with Domino.
ok console log, ends with
[3144:0002-32A0] 10/04/2020 01:59:43 AM SwiftFile: SwiftFile process exited abnormally. Exit code: 0.
Why would swiftfile care if I am not doing anything with it I wonder.
Anway, I changed log level to 5, will see what we get.
I have told swiftfile to be disabled to see if it matters.
odd that a code 0 is used. In c that is often used for no error... I suspect another process is crashing, taking SwiftFile with it.
Could you provide more lines?
Still no luck, now I see it is shutting down 76 hours later instead of 72.
The last thing in the log this time, since swiftfile was shut down, is this:
[0758:0002-2574] 10/08/2020 08:12:03.04 PM ChangeWCTTabTitle> Returned DWORD: 0
[3894:000E-0A9C:AgentMgr] 10/08/2020 08:26:16 PM Agent Manager shutdown
The below is 5 hours earlier, the DWORD:0 line runs from 3:29 to 8:12 every 3 minutes which coincides with how often it checks for the new mail/replicates.
Copying to location doc
[2EC8:0002-0FCC] 10/08/2020 03:29:39 PM Dynamic Client Configuration shutdown
[0758:0002-2574] 10/08/2020 03:29:45.36 PM ChangeWCTTabTitle> Returned DWORD: 0
If log file size becomes a problem, please look at Console_log_mirror, ConsoleLogMax_KBytes and Retain_Mirror_Logs settings to manage how the log files are handled.
I must confess not to have tested all these variables extensively, but I just wanted to give you some possibilities.
Also it helps to read back from the last line. Often times Notes and Domino try to soldier on, only failing when it really cannot go on. With the root cause or fail occurring somewhat earlier. Sorry i cannot be more precise... ;-)
