I cannot get Notes up and running. the screenshots below show what I see when I start Notes.
there is no location in button corner, there is no bookmarks, CTRL-O does not work etc.
I provide screenshots and log and hope someone can make something out of them.
I have tried to run the installer again with the “Modify” option but that does not help.
Error when starting Notes
This is the only thing I see when clicking the open button
This is error-log-0.xml
<?xml version="1.0" encoding="UTF-8"?> <?xml-stylesheet type="text/xsl" href="Log_Viewer.xml"?><extendedDataElements name="CommonBaseEventLogRecord:level" type="noValue">
<children name="CommonBaseEventLogRecord:name" type="string">
<values>SEVERE</values>
</children>
</extendedDataElements>
<extendedDataElements name="CommonBaseEventLogRecord:sourceClassName" type="string">
<values>com.ibm.workplace.noteswc.NoteswcPlugin</values>
<extendedDataElements name="CommonBaseEventLogRecord:sourceMethodName" type="string">
<values>writeToLog</values>
<sourceComponentId component="Expeditor 6.1" componentIdType="ProductName" instanceId="1215176273506" location="192.168.0.4" locationType="IPV4" subComponent="com.ibm.workplace.noteswc" threadId="11" componentType="http://www.w3.org/2001/XMLSchema-instance"/>
<situation categoryName="ReportSituation">
<situationType xmlns:xsi="ReportSituation" reasoningScope="INTERNAL" reportCategory="LOG"/>
</situation>
</children>
<extendedDataElements name="CommonBaseEventLogRecord:Exception" type="string">
<values>java.lang.NullPointerException
	at com.ibm.rcp.aaf.startup.Activator.earlyStartup(Activator.java:237)
	at com.ibm.rcp.aaf.startup.Startup.earlyStartup(Startup.java:22)
	at com.ibm.rcp.personality.framework.internal.PersonalityStartup$PersonalityStartupDescriptor.run(PersonalityStartup.java:103)
	at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
	at org.eclipse.core.runtime.Platform.run(Platform.java:843)
	at com.ibm.rcp.personality.framework.internal.PersonalityStartup$PersonalityStartupDescriptor.execute(PersonalityStartup.java:82)
	at com.ibm.rcp.personality.framework.internal.PersonalityStartup.executeStartup(PersonalityStartup.java:194)
	at com.ibm.rcp.personality.framework.internal.PersonalityStartup.access$2(PersonalityStartup.java:178)
	at com.ibm.rcp.personality.framework.internal.PersonalityStartup$1.run(PersonalityStartup.java:160)
	at org.eclipse.core.intern</values>
<values>al.jobs.Worker.run(Worker.java:58)
</values>
<sourceComponentId component="Expeditor 6.1" componentIdType="ProductName" instanceId="1215176273506" location="192.168.0.4" locationType="IPV4" subComponent="com.ibm.rcp.personality.framework" threadId="12" componentType="http://www.w3.org/2001/XMLSchema-instance"/>
</situation>
</children>
<values>com.ibm.workplace.noteswc.NoteswcPlugin$1</values>
<values>done</values>
</situation>
</children>
<values>com.ibm.rcp.personality.framework.internal.PersonalityStartup</values>
<values>executeStartup</values>
</values>
<sourceComponentId component="Expeditor 6.1" componentIdType="ProductName" instanceId="1215176273506" location="192.168.0.4" locationType="IPV4" subComponent="com.ibm.rcp.personality.framework.internal" threadId="12" componentType="http://www.w3.org/2001/XMLSchema-instance"/>
</situation>
</children>
<values>com.ibm.rcp.propertybroker.internal.Activator</values>
<values>processWires</values>
<values>com.ibm.rcp.propertybroker.service.PropertyBrokerAlreadyDefinedException: Wire:03762D87A3E9CD0A2CCDA3DD6BE9ADAD_3aabf8894dc8e8a61831397210ff300c19c7ff9 is already registered
	at com.ibm.rcp.propertybroker.internal.PropertyBrokerImpl.registerWires(PropertyBrokerImpl.java:1085)
	at com.ibm.rcp.propertybroker.internal.Activator.processWires(Activator.java:662)
	at com.ibm.rcp.propertybroker.internal.Activator.init(Activator.java:244)
	at com.ibm.rcp.propertybroker.internal.Activator.access$2(Activator.java:189)
	at com.ibm.rcp.propertybroker.internal.Activator$initJob.run(Activator.java:827)
	at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)
</values>
<sourceComponentId component="Expeditor 6.1" componentIdType="ProductName" instanceId="1215176273506" location="192.168.0.4" locationType="IPV4" subComponent="com.ibm.rcp.propertybroker" threadId="15" componentType="http://www.w3.org/2001/XMLSchema-instance"/>
</situation>
</children>
<values>com.ibm.rcp.propertybroker.service.PropertyBrokerAlreadyDefinedException: Wire:03762D87A3E9CD0A2CCDA3DD6BE9ADAD_3aabf8894dc8e8a61831397210ff300c19c7ff7 is already registered
</values>
</situation>
</children>
<values>com.ibm.rcp.propertybroker.service.PropertyBrokerAlreadyDefinedException: Wire:03762D87A3E9CD0A2CCDA3DD6BE9ADAD_3aabf8894dc8e8a61831397210ff300c19c7ff5 is already registered
</values>
</situation>
</children>
<values>java.lang.ExceptionInInitializerError
	at java.lang.J9VMInternals.initialize(J9VMInternals.java:216)
	at com.ibm.collaboration.realtime.im.community.accountstore.internal.AccountStoreMgr.getCommunityCredential(AccountStoreMgr.java:119)
	at com.ibm.collaboration.realtime.login.LoginUtil.getPassword(LoginUtil.java:416)
	at com.ibm.collaboration.realtime.login.LoginEarlyStartup.createLoginContext(LoginEarlyStartup.java:160)
	at com.ibm.collaboration.realtime.login.LoginEarlyStartup.autoLogin(LoginEarlyStartup.java:144)
	at com.ibm.collaboration.realtime.login.LoginEarlyStartup.doStartLogin(LoginEarlyStartup.java:125)
	at com.ibm.collaboration.realtime.login.LoginEarlyStartup.startLogin(LoginEarlyStartup.java:108)
	at com.ibm.collaboration.realtime.login.LoginEarlyStartup$1.run(LoginEarlyStartup.java:76)
Caused by: java.lang.Nul</values>
<values>lPointerException
	at com.ibm.collaboration.realtime.im.community.accountstore.internal.AccountStoreHelper.init(AccountStoreHelper.java:63)
	at com.ibm.collaboration.realtime.im.community.accountstore.internal.AccountStoreHelper.<init>(AccountStoreHelper.java:50)
	at com.ibm.collaboration.realtime.im.community.accountstore.internal.AccountStoreHelper.<clinit>(AccountStoreHelper.java:43)
	at java.lang.J9VMInternals.initializeImpl(Native Method)
	at java.lang.J9VMInternals.initialize(J9VMInternals.java:194)
	... 8 more
</values>
<sourceComponentId component="Expeditor 6.1" componentIdType="ProductName" instanceId="1215176273506" location="192.168.0.4" locationType="IPV4" subComponent="org.eclipse.core.jobs" threadId="13" componentType="http://www.w3.org/2001/XMLSchema-instance"/>
</situation>
</children>
<values>com.ibm.rcp.toolbox.admin.Activator</values>
<values>getDispatcherService</values>
<sourceComponentId component="Expeditor 6.1" componentIdType="ProductName" instanceId="1215176273506" location="192.168.0.4" locationType="IPV4" subComponent="com.ibm.rcp.toolbox.admin.Activator" threadId="17" componentType="http://www.w3.org/2001/XMLSchema-instance"/>
</situation>
</children>
	at org.eclipse.core.internal.jobs.Worker.run(Worker.java:73)
</values>
<sourceComponentId component="Expeditor 6.1" componentIdType="ProductName" instanceId="1215176273506" location="192.168.0.4" locationType="IPV4" subComponent="org.eclipse.core.jobs" threadId="12" componentType="http://www.w3.org/2001/XMLSchema-instance"/>
</situation>
</children>
<values>com.ibm.rcp.portal.app.internal.activator.CaiPlugin$initJob</values>
<values>run</values>
	at com.ibm.rcp.accounts.internal.AccountsManagerImpl.init(AccountsManagerImpl.java:135)
	at com.ibm.rcp.accounts.internal.AccountsManagerImpl.getInstance(AccountsManagerImpl.java:337)
	at com.ibm.rcp.accounts.AccountsManagerFactory.getAccountsManager(AccountsManagerFactory.java:31)
	at com.ibm.rcp.portal.app.internal.activator.CaiPlugin$initJob.run(CaiPlugin.java:807)
</values>
<sourceComponentId component="Expeditor 6.1" componentIdType="ProductName" instanceId="1215176273506" location="192.168.0.4" locationType="IPV4" subComponent="com.ibm.rcp.portal.app" threadId="18" componentType="http://www.w3.org/2001/XMLSchema-instance"/>
</situation>
This is trace-log-0.xml
<?xml version="1.0" encoding="UTF-8"?> <?xml-stylesheet type="text/xsl" href="Trace_Viewer.xml"?><extendedDataElements name="CommonBaseEventLogRecord:level" type="noValue">
<values>CONFIG</values>
</children>
<values>com.ibm.rcp.core.internal.logger.frameworkhook</values>
<values>writeSession</values>
<sourceComponentId component="Expeditor 6.1" componentIdType="ProductName" instanceId="1215176273506" location="192.168.0.4" locationType="IPV4" subComponent="com.ibm.rcp.core.internal.logger.frameworkhook" threadId="10" componentType="http://www.w3.org/2001/XMLSchema-instance"/>
</situation>
</children>
</situation>
</children>
</values>
</situation>
</children>
</situation>
</children>
</values>
</situation>
<values>INFO</values>
</children>
<sourceComponentId component="Expeditor 6.1" componentIdType="ProductName" instanceId="1215176273506" location="192.168.0.4" locationType="IPV4" subComponent="SystemOut" threadId="13" componentType="http://www.w3.org/2001/XMLSchema-instance"/>
</situation>
</children>
</values>
</situation>
</children>
</values>
</situation>
</children>
</values>
</situation>
</children>
	... 8 more
</values>
</situation>
</children>
</situation>
</children>
</values>
</situation>
</children>
</values>
</situation>
<extendedDataElements name="CommonBaseEventLogRecord:multipleMessageValues" type="string">
<values>
	at com.ibm.notes.java.api.util.NotesJob$1.run(NotesJob.java:50)
	at com.ibm.notes.java.api.util.NotesSynchronizer$RunnableLock.run(NotesSynchronizer.java:141)
	at com.ibm.notes.java.api.util.NotesSynchronizer.runSyncMessages(NotesSynchronizer.java:114)
	at com.ibm.notes.java.api.util.NotesPlatform.readAndDispatch(NotesPlatform.java:65)
	at com.ibm.notes.java.api.util.NotesPlatform.access$100(NotesPlatform.java:29)
	at com.ibm.notes.java.api.util.NotesPlatform$1.run(NotesPlatform.java:51)
</values>
</children>
<sourceComponentId component="Expeditor 6.1" componentIdType="ProductName" instanceId="1215176273506" location="192.168.0.4" locationType="IPV4" subComponent="SystemErr" threadId="17" componentType="http://www.w3.org/2001/XMLSchema-instance"/>
</situation>
