WebQuerySave and $$Return and field validation using javascript
I have a form with a “Submit” button with javascript code that validates fields. Here is the code:if(validate(frm.RequestorName) && validateSenator() && validate(frm.MailDate) && validateCreateLabel())
// _getEditAppletData();
frm.submit();
frm.close();
Then in the WebQuerySave event I call an agent, here is the code:
@Command([ToolsRunMacro]; “SendCWEmail”);
@Command([FileCloseWindow])
I also have a $$Return field on the form with the value:
So, my problem is after I click on Submit, it triggers the email agent but it does not bring me back to the OpenOrders form, instead it leaves me on a white blank screen. So, my question is, how do I get back to the form that is named in the $$Return field. This works when I take out the code in WebQuerySave. But, I need to call the agent after it submits the document, so I need to keep the code in WebQuerySave. Any suggestions?
Subject: WebQuerySave and $$Return
Since your $$Return seems only to open a form, perhaps you can use the formula language instead of JavaScript. I routinely use WebQuerySave to send email confirmation, then I present the user with a message and a link to the URL where they should go. Yes, this does not force them there like you want, but perhaps it will help get you closer to what you want.
Thank you for your registration.
Click here for the HR Form
Subject: Place $$Return code inside @Return
Christine, I placed your code inside of an @Return, and that worked for me.
@Return(
Subject: found solution
I solved the problem by putting this statement as the last line in the LotusScript agent:
Print “[”+“http://server/Helpline.nsf/Home?OpenForm"+"]”
