Web service problem with IBM Certificate patch
i’m using web services in Domino and it works fine.
Well, it worked fine until i installed an IBM patch for security certificate expiration messages (http://www-01.ibm.com/support/docview.wss?rs=899&uid=swg21381298).
After installing this patch, it appears that my function in the web service cannot take one parameter otherwise it generates an error.
After some tests, i uninstalled the patch and it worked fine again.
But still, what’s happening ? Has someone experience it ?
Subject: Did you see this?
http://www-01.ibm.com/support/docview.wss?rs=899&uid=swg24022981
Howard
Subject: ok with this
thx a lot.
