Hello,I’ve a problem with saving a calculated field on web.
Problem description:
I’ve a calculated field (field_1) in a web application and I fill in a value (p.e. “Hello”) using an agent.
button_fillin:
@Command([ToolsRunMacro]; “(ag_fillin)”);
(ag_fillin):
@SetField(“field_1”;“Hello”);
button_save:
@Command([FileSave]);
@Command([FileCloseWindow)];
When I open this document, field_1 is empty. So it hadn’t save correctly.
When I try this in Notes it works!
When I change field_1 to “editable” an click “fillin” and then “save” it works in web!
I dont know where the problem is…
I hope you can help me.
I don’t know why
