Web Replacement - ComposeDocument
I have an agent, which i call from a button on a web form. I would like to create a document in the database by using the agent…usually, I would do this by ws.ComposeDocument(“”,“”,“FormName”). How would i do this in a web agent?
Thanks!
F1H
Subject: Web Replacement - ComposeDocument
build a url that looks like:
http://domino1/BadCheck1.nsf/BIRRegister?OpenForm
where birregister is the name of the form. Read more on OpenForm in the Designer help to see what else you can do with this url command to pass data between forms and so on.
to break this down we have
http:// - the protocol used (generally http or https)
domino1 - the host dns
BadCheck1.nsf - the database name
BIRRegister - the form to be opened
?OpenForm - the command to run
Other URL commands are listed in the help. Some useful ones are:
ReadForm (opens the form in read mode)
OpenDocument
EditDocument
OpenPage
OpenView
OpenAgent
ReadViewEntries (shows the xml generated by a view)
There are other url commands for searching, and basically everything you could want to do, almost. Look in the help.
Subject: RE: Web Replacement - ComposeDocument
Thanks very much for your help - I now have a starting point!
Appreciate it.
F1H
How do I pass values into the form?
I have tried “&fieldname=test” at the end of the URL - but it doesnt work.
Any suggestions?
F1H
Well,
U can call create a URL for the form u want to compose.
Please check Domino Designer help for more details.
Tom
Any suggestions?
F1H
You can try this…
Pass the value as “&fieldname=test”.In the form, in the respective field, use @urlquerystring(fieldname) as the value…
