Let’s say you have a document opened on web, the usual way (“db.nsf/view/doc?open”), and from this doc, you want to navigate to next document in the view, within the category. Navigate next hotspot could be accomplished, using a “?Navigate&TO?Next”, but this command only navigates to the next document, it can’t pass on url parameters as well. Is the only workaround, to have a LS agent?
Best regards,
Rune Carslen
