Web Login - works with redirection but not direct
hi!
i configured the WebMailRedirect from IRIS SANDBOX to have access for my users via webmail. it works pretty perfect.
but:
when i try to open a database (even a mail-db) directly out of the browser, i get the login-screen again and again anad again…
for example, when i try to open the url
http://myserver/mail/mymaildb.nsf?Login
i’m prompted for username+pwd (it’s the login-prompt of DOMCFG). when i enter my login information, i see that page again. and again. and again.
this happens to ANY database i’ll try to access.
any idea?
regards
/matthias
Subject: Web Login - works with redirection but not direct
Make sure you have Anonymous in the ACL of the databases you wish to access and that Anonymous is set to NO ACCESS.
Subject: RE: Web Login - works with redirection but not direct
it is set.if it would not, NO login form would appear at all.
/matt
Check if you have single sign on enabled
If so, you must supply the FULL FQDN (with domain) in the URL - otherwise you will get the symptoms you mention.
G.
