I am having problems with one of my views. I have a field, which is a multi-valued text field. I set up the delimiters for each entry as either a comma, a semicolon, or a new line and I set it up to display in the form as a new line between each entry. That works fine. In the view, I have the same field included as a non-categorized, non-sorted column. In the column properties, I selected “display multiple values as separate entries” but the view shows only one entry with the first value in my multi-valued field. This should be very straight forward so I wonder if this is an issue with 7.0.1. Has anyone else experienced this problem?
Thanks in advance for your response.
