Very big problem with EmbeddedObjects
Hi
I have a form with a Richtext field. In this field, user can attach documents. In QuerySave event I want to check size of attachments to cancel save event if attachments are greater than 1M. How I can do this using lotuscript.
Subject: Very big problem with EmbeddedObjects
EmbeddedObjects or attachments?
you can’t. why LS, use @Formula
Subject: RE: Very big problem with EmbeddedObjects
I have a similar problem:
I use the code below and get all attachments, but not the graphic that’s in the body:
If Isarray(rtItem.EmbeddedObjects) Then
Forall Object In RTItem.EmbeddedObjects
  Select Case Object.Type
Case EMBED_ATTACHMENT:
   Messagebox "Attachment"
Case EMBED_OBJECT:
   Messagebox "Embedded"
  End Select
End Forall
Any idea what’s wrong with this? I’ve been banging my head against the wall for days on this.
Thanks,
Peter Mello
I think you’ll find that graphics are in-line data rather than embedded objects.
Thanks for the reply, but the help files indicate that OLE objects are accessed via EmbeddedObjects. Is there documentation that discusses the methodology you describe?
Thanks again,
Peter Mello
That’s what I’m getting at – an inline image is not an OLE object. It’s a “splat” of data sitting in the rich text field – just bytes that paint a picture with header “tags” that apply the properties. Fundamentally not different from a paragraph, except that it’s difficult to read in a text editor. You can access the picture as a file if you get the document by HTTP URL, you can get a Base64 version as a NotesBitMap or a GIF by exporting as DXL, or you can use the C API (or a third-party tool like the Midas Rich Text LSX – I think Midas does this) to dig out the image bytes and create an image file.
I tried this code and the object “mime” is always nothing:
Dim mime As NotesMimeEntity
Dim stream As NotesStream
Set mime=doc.GetMIMEEntity
If Not(mime Is Nothing) Then
If mime.ContentType = “image” Then
  Set stream = session.CreateStream
  pathname$ = AppPath & "\temp\image." & mime.ContentSubtype
 If Not stream.Open(pathname$, "binary") Then
    Messagebox pathname$,, "Open failed"
Goto NormalExit 'exit app
 Call mime.GetContentAsBytes(stream)
 Call stream.Close()
Else
  Messagebox "Not an image",,doc.GetItemValue("Subject")(0)
Else
Messagebox “Not MIME”, doc.GetItemValue(“Subject”)(0)
Where did you get the idea that inline Notes data is MIME?
As Stan points out, normal Notes rich text data is not MIME, it is a stream of CD (Composite Data) records stored across a potential series of items. It is possible to set a rich text field to “Save as HTML and MIME”, which would allow access the way you suggest, but you lose quite a bit in the bargain, both because the translation is not great and because any translation back and forth between two formats will entail loss over time.
