Varient does not contain a container
When going to archive the mails it is giving the message varient does not contain a container.
I have done following procedures individually, but no solved.
  1. fix up the database.
2)Refresh design.
3)Replace design.
Subject: Varient does not contain a container
Do you archive your mails by using standard database archiving tool or someone’s script by pressing some action button or running some agent?If second, point to the File\Tools\Debug LotusScript and watch what is going on and where is and error and call for support
