Hi all.
We had Java agent that connects to MQ server and reads messages from it. It works fine on Domino 6.5 for a long time. Than we moved this agent on Domino 8.5 and it produces memory leak and OutOfMemory as result.
I investigated it and found that problem is with using of MQQueueConnectionFactory. We create this factory, than create JMSTemplate and set factory to template. And finally receive messages.
Code is:
To create factory:
public void connect(String hostName, int port, String mqManager, String channel) {
cf = new MQQueueConnectionFactory();
qManagerName = mqManager;
try {
cf.setQueueManager(mqManager);
cf.setHostName(hostName);
cf.setPort(port);
cf.setTransportType(1);
if (channel != null && channel.length() > 0) {
cf.setChannel(channel);
} catch (JMSException e) {
e.printStackTrace();
And to read messages:
public String readMessage() {
String result = null;
try {
JmsTemplate t = new JmsTemplate();
t.setConnectionFactory(cf);
t.setDefaultDestination(q);
t.setReceiveTimeout(2000);
Message resultMsg = t.receive();
if (resultMsg != null) {
result = ((TextMessage) resultMsg).getText();
return result;
In all possible places recyle() is invoking.
Max heap size is 512 Mb. When agent run on 8.5 server it takes additional ~50-60Mb per launch. Increasing to 1Gb just allow to have several more launches. Agent is invoking as RunOnServer from Agents list.
Any ideas?
Thanks in advance
