Using CreateViewNavFromCategory not working
Can someone tell me what’s wrong with this code? I have view based on dates and am trying to determine the work schedule for a particular week but it’s not finding the view entries.
There are entries are there… says entry is nothing
Dim memo As NotesDocument
Set memo = New NotesDocument(db)
Call dbug.LogAction("memo is set")
’ memo.Subject = "Schedule for the week of " & Cstr(Date)
memo.Principal=db.Title
Set rtitem = New notesrichtextitem(memo, "Body")
Call dbug.LogAction("set new rtitem")
Set object = rtitem.EmbedObject ( EMBED_ATTACHMENT, "", fileName$, "Filler" )
Call dbug.LogAction("set object")
Set searchView = db.GetView("DAYSOUTNEXTWEEK")
Call dbug.LogAction("search is set")
Dim StartDate As New NotesDateTime(Date)
Dim wd As Integer
wd%=Weekday(StartDate.DateOnly)
Call StartDate.AdjustDay(2-wd)
Stop
Dim EndDate As New NotesDateTime(StartDate.DateOnly)
Call EndDate.AdjustDay(4)
Dim columnValue1 As Variant
Dim columnValue2 As Variant
Dim xdate As Variant
Dim modifiedDateTime As NotesDateTime
Dim entryDoc As notesviewentry
memo.Subject = "Schedule for the week of " & Cstr(StartDate.DateOnly) & " - " & Cstr(EndDate.DateOnly)
Call dbug.LogAction(" week of " & Cstr(StartDate.DateOnly) & " - " & Cstr(EndDate.DateOnly))
Call rtitem.AddNewline(1)
Call rtitem.AppendText("The following associates will not be here the week of " & Cstr(StartDate.DateOnly) & " - " & Cstr(EndDate.DateOnly))
For i=0 To 4
	Call StartDate.AdjustDay(i)
	Set nav=searchView.CreateViewNavFromCategory(StartDate.DateOnly)
	Call dbug.LogAction("viewnav is set")
	Set entry = nav.GetFirst
	If entry Is Nothing Then
		Print "everyone is here"
		Call dbug.LogAction(Cstr(StartDate.DateOnly) & ": everyone is here")
		Call rtitem.AppendText(Cstr(StartDate.DateOnly))
		Call rtitem.AppendText("There are no scheduled attendance records for this day.")
	Else
		Call rtitem.AddNewline(2)
		If entry.ChildCount >0 Then
			If entry.IsCategory Then			'
				columnValue1 = entry.ColumnValues(0)
				If Isarray(columnValue1) Then
					Print "entry.ColumnValues ="& Implode(columnValue1, ",")
					xdate= Implode(columnValue1, ",")
				Else
					Print "entry.ColumnValues ="& columnValue1
					xdate=columnValue1
				Call rtitem.AppendText(xdate)
				Set entryDoc=nav.GetChild(entry)
				While Not entryDoc Is Nothing
					columnValue2 = entryDoc.ColumnValues(1)
					Call rtitem.AddTab(1)
					If Isarray(columnValue2) Then
						Print "entryDoc.ColumnValues ="& Implode(columnValue2, ",")
						Call rtitem.AppendText(Implode(columnValue2, ","))
					Else
						Print "entryDoc.ColumnValues ="& columnValue2
						Call rtitem.AppendText(columnValue2)
					Set entryDoc=nav.GetNextSibling(entryDoc)
				Wend
Next
sendMail:
Subject: using CreateViewNavFromCategory not working
I believe it’s a datatype issue. DateOnly returns a string; your view is probably sorted by date/time values, not by text values. The doc for CreateViewNavFromCategory expects its argument to be a string, so there may be no way to use it in a view that’s categorized by non-text values.
Is there a reason you can’t use NotesView.GetAllEntriesByKey instead? (I’m not sure whether the results will be in view order.)
Subject: RE: using CreateViewNavFromCategory not working
I get nothing with Cstr(StartDate.DateOnly) or StartDate.DateOnly:
For i=1 To 5
	Set vc=searchView.GetAllEntriesByKey(Cstr(StartDate.DateOnly),True)
	Print Cstr(vc.Count) " docs found for " & Cstr(StartDate.DateOnly)
	Call StartDate.AdjustDay(1)
	Stop
Next
Stop
My documents may have multivalues in the field - so I explode it in the column. I’m sure this is part of the issue (just realized I should have included that in my original post)
What I think may work is this:
If (EndDate.TimeDifference( modifiedDateTime )/86400) < 5 And (EndDate.TimeDifference( modifiedDateTime )/86400) >=0 Then
			boolDate=True
			Print "END DATE: " &Cstr((EndDate.TimeDifference( modifiedDateTime )/86400) ) & " is < 5 & >=0"
			Print "START DATE: " & Cstr((StartDate.TimeDifference( modifiedDateTime )/86400) )
		Else
			boolDate=False
		While boolDate=True...
but I just need to break out of my Wend - how do I do that? Or probably use a sub routine…
ideally I would like to step through the entire (unfiltered) view and just pull the dates and subcategories I need. I will try using a sub routine - that would solve most of my anguish I think, right? If the date falls in between those dates then start populating mail message…
Here is what “works” (it’s ugly):
my view selection formula (more dates show up than I want because multiple dates entered in the multivalued field):
x:=@TextToTime(@Explode(dateout));
SELECT x>= @Adjust(@Now; 0; 0; 1-@Weekday(@Now); 0; 0; 0) & x<= @Adjust(@Now; 0; 0; 6-@Weekday(@Now); 0; 0; 0)
First Column:
Sub Initialize
’ Agent Runs On Monday morning, gives schedule for the week
On Error Goto errtrap
Dim dbug As New NotesLog("Agent log")
Call dbug.OpenAgentLog
Dim s As New NotesSession
Dim dc As NotesDocumentCollection
Dim db As notesdatabase 			' CURRENT DB
Dim dbERR As notesdatabase 	' CURRENT DB
Dim vc As NotesViewEntryCollection
Dim view As notesview
Dim doc As notesdocument
Dim DayofWeek As String
Dim nav As NotesViewNavigator
Dim searchView As notesview
Dim entry As NotesViewEntry
Dim agent As NotesAgent
Dim n As String
Dim gmtdate As String
Dim docID As String ' Variable to hold document Universal ID
Dim ReplicaID As String ' Variable used to build Replica ID line in .NDL file
Dim HintServer As String ' Variable used to build hint server line in .NDL file
Dim ViewID As String ' Variable used to build view line in .NDL file
Dim NoteID As String ' Variable used to build document line in .NDL file
Dim rtitem As NotesRichTextItem
Dim object As NotesEmbeddedObject
Dim filename As String
’ Option Declare
Dim sendto As Variant
Dim ERRRTITEM As NotesRichTextItem
Dim ERRMEMO As NotesDocument
Dim ERRTXT As String
Set agent = s.CurrentAgent
If agent Is Nothing Then dbug.LogAction("agent is not set") Else dbug.LogAction("agent is set")
n = agent.Name
Set db=s.CurrentDatabase
Call dbug.LogAction("db is set")
Set view = db.GetView("Calendar")
If view Is Nothing Then dbug.LogAction("view is not set") Else dbug.LogAction("view is set")
' create ndl here
%REM
’ Verify that the document current exist in the database
If doc.IsNewNote Then
’ Document has not been saved, warn user and exit routine
	'		Msgbox "This document has not been saved." & Chr$(10) & Chr$(10) & "Please save prior to mailing link!", 4112, "New Document"
	ERRtxt=	"This document has not been saved." & Chr$(10) & Chr$(10) & "Please save prior to mailing link!"
	Call dbug.LogAction(ERRtxt)
	Print ERRtxt
	Goto errtrap
Else
’ Lets get the documents I.D.
	docID = doc.UniversalID
	Call dbug.LogAction("UNID: " & docID)
%END REM
’ Lets ensure that user is not attempting to send a link of a local database
If db.server = "" Then
’ This is a local database and mailed link will not work, warn user and exit routine
’ Msgbox “You are not allowed to send a link of a local database”, 4112, “Local Links Not Allowed”
	ERRtxt= "You are not allowed to send a link of a local database"
	Print ERRtxt
	Goto errtrap
Else
’ Build Replica line for .NDL file format = <REPLICA 8525643D:0069F618>
	ReplicaID="<REPLICA " & Left$(db.ReplicaID, 8) & ":" & Right$(db.ReplicaID, 8) & ">"
	Call dbug.LogAction("ReplicaID: " + ReplicaID)
ViewID = ""
' Lets verify that a default view exist in this database as a view handle is need for the .NDL file
' Build View line for .NDL file format = <VIEW OF0BA62705:23C5A6D0-ON8525643D:006A3AA7>
ViewID = "<VIEW OF" & Left$(view.UniversalID, 8) &":"&Mid$(view.UniversalID, 9, 8)&"-"&"ON"&Mid$(view.UniversalID, 17, 8)&":"&Right$(view.UniversalID, 8)&">"
Call dbug.LogAction("ViewID: " + ViewID)
%REM
Forall x In db.Views 'Use ForAll to loop through each view in the database until the default is found
	If Not(x.name="My Favorites" Or x.name="(My Favorites)") Then
		If x.isprivate=False Then
			If x.IsDefaultView Then 'Test each view to see if it is the default view
’ Build View line for .NDL file format =
				ViewID = "<VIEW OF" & Left$(x.UniversalID, 8) &":"&Mid$(x.UniversalID, 9, 8)&"-"&"ON"&Mid$(x.UniversalID, 17, 8)&":"&Right$(x.UniversalID, 8)&">"
				Exit Forall 'Once the default view is found, break out of the loop
End Forall
%END REM
’ Lets ensure that our view handle for the .NDL file was built
If ViewID = "" Then
’ View handle was never built so link would give a view error, warn user and exit routine
		'	Msgbox "This database does not contain a default view." & Chr$(10) & Chr$(10) & "Please contact your database manager!", 4112, "Default View Not Found"
	ERRtxt= "This database does not contain a default view." & Chr$(10) & Chr$(10) & "Please contact your database manager!"
	Print ERRtxt
	Goto errtrap
%REM
’ Build Note line for .NDL file format =
NoteID = "<NOTE OF" & Left$(docID, 8) &":"&Mid$(docID, 9, 8)&"-"&"ON"&Mid$(docID, 17, 8)&":"&Right$(docID, 8)&">"
Call dbug.LogAction("NoteID: " + NoteID )
%END REM
’ Build Hint Server line for .NDL file format = CN=FTLNSDEV/OU=DEV/O=FTG
HintServer = "<HINT>"& db.server &"</HINT>"
Call dbug.LogAction("HintServer:" & HintServer )
‘’ Assign a file name for the .NDL file that we will be mailing
’ Write out link data to C:\link.ndl
Dim fileNum As Integer
fileNum% = Freefile()
'Open “c:\test\test.html” For Output As fileNum%
fileName$ = "c:\temp\CalendarLink.ndl"
Call dbug.LogAction("filename: " & filename$)
Print filename$
Open filename$ For Output As fileNum%
Call dbug.LogAction("file opened for input")
Print "file opened for input"
Print #fileNum%, "<NDL>"
Print #fileNum%, Cstr(ReplicaID)
Print #fileNum%, Cstr(HintServer)
Print #fileNum%, Cstr(ViewID)
’ Print #fileNum%, Cstr(NoteID)
Print #fileNum%, "</NDL>"
Close fileNum%
Print "file created"
Call dbug.LogAction("ndl file created")
Dim wd As Integer
Stop
xdate=StartDate.DateOnly
Dim boolDate As Boolean
Set modifiedDateTime = New NotesDateTime( xdate )
Print Cstr(EndDate.TimeDifference( modifiedDateTime )/86400) & " days"
Set nav = searchView.CreateViewNav()
Set vc=searchView.AllEntries
Call dbug.LogAction("vc is set")
If vc.Count=0 Then
	Call dbug.LogAction("everyone is here")
	Call rtitem.AppendText("There are no scheduled attendance records for this week.")
	Goto sendMail
Else
	Stop
		'do something
		Goto sendMail
	Else
			boolDate=True
		Else
			boolDate=False
		While boolDate=True
’ Print “entry.ColumnValues =”& Implode(columnValue1, “,”)
				Else
					xdate=columnValue1
’ Call rtitem.AppendText(columnValue1)
				Stop
					boolDate=True
				Else
					boolDate=False
					Goto sendMail
%REM
			If (StartDate.TimeDifference( modifiedDateTime )/86400) < 5  Then
				Print "START DATE: " & Cstr((StartDate.TimeDifference( modifiedDateTime )/86400) ) & " is less than 5"
’ Goto next entry
			Elseif (StartDate.TimeDifference( modifiedDateTime )/86400) > 5  Then
				Print "START DATE: " &Cstr((StartDate.TimeDifference( modifiedDateTime )/86400) ) & " is greater than 5"
%END REM
			Else
	'				Print "END DATE: " &Cstr((EndDate.TimeDifference( modifiedDateTime )/86400) ) & " is less than 5 and greater than or equal to 0"
	'				Print "START DATE: " & Cstr((StartDate.TimeDifference( modifiedDateTime )/86400) )
		''	Elseif (EndDate.TimeDifference( modifiedDateTime )/86400) > 5  Then
				Else
					Print "END DATE: " &Cstr((EndDate.TimeDifference( modifiedDateTime )/86400) ) & " is greater than 5 and less than 0"
					Goto nextentry
’ Goto send mail
				columnValue2 = entry.ColumnValues(1)
					Print "entry.ColumnValues ="& Implode(columnValue2, ",")
				Else
					Print "entry.ColumnValues ="& columnValue2
nextentry:
			Set entry=nav.GetNext(entry)
'		Set entry=nav.GetNextDocument(entry)
		Wend
sendMail:…
I feel like I am cheating a little when I do this but this works:
For i=1 To 5
	cmd={@DbLookup( "" : "NoCache" ; "} & db.Server & {" : "} & path & {" ; "DAYSOUTNEXTWEEK" ; ([} & modifiedDateTime.DateOnly & {]) ; 2);}
	results = Evaluate(cmd)
	Call rtitem.AppendText( modifiedDateTime.DateOnly)
	If Isempty(results) Then
'		Call rtitem.AddNewline(1)
		Call rtitem.AppendText("No scheduled absences.")
	Else
		Forall v In results
			Call rtitem.AppendText(v)
		End Forall
	Call  modifiedDateTime.AdjustDay(1)
Next
