If you have a scenario where a Notes Client is unable to find a server - looking at last known address and you add a Connection Document, am I right in thinking this Connection Document is then always used first to locate the server - in effect becoming a static route.
Or will the client still try to look at last known addresses before eventually using Connection Documents?
Carl.
