Subject: Another user experience with passthru
This was reported to me via e-mail:I have recently downloaded 8.5 Beta 2 and installed it on two of my machines. One is running under WinXP, the other runs Ubuntu. I have the same problem as was reported in the forum thread under both installations. I probably should add that our server
I want to connect from my home office to my corporate Domino server. To do so, I need to go through a passthru server. My location is configured all fine, I think. I can trace the server all right and I get a list of DBs and directories when I go through the “Open Application” dialog (Ctrl-O). When I do this (Ctrl-O), I get the following messages in the status bar:
Connecting to Pass01/[…]
Connected to Pass01/[…]
Asking server for connection to Mail02/[…]
Connecting to Mail02/[…]
Connected to Mail02/[…]
Network traffic is being encrypted on the server’s request…
However, if I try to open my inbox, the client enters a loop where it keeps going through the messages quoted above. After being connected to the mail server it restarts the whole cycle of going to the passthru server, asking for a connection, connecting, encrypting… I can stop it using Ctrl-Break or by switching to an offline location (even though it takes a while until the client reacts), but the client will restart almost immediately, probably trying to check for unread mail or so.
Now the following only applies to the Ubuntu box, I’d have to swap harddisks to go to WinXP to check for the same behavior.
While I was writing the last paragraph, it occured to me, that I may want to try another DB. I tried the Domino Directory and that worked fine. And guess what, after I opened that, I could even open my inbox. I could reproduce the behavior: shutdown the Notes client, restart it, try to open the inbox via passthru: running into the error; stopping that action, opening the Domino Directory: works fine; trying to open the inbox again: works fine.
I can imagine that this sounds like a nightmare to debug. And the Notes log (log.nsf) doesn’t seem to help either, since it only contains entries concerning the Dynamic Client Configuration (in the misceallaneous events view). The security events view doesn’t show any entries, neither does the mail routing view (well, I’m not on a local mail file, so I guess that only makes sense).
If there is an INI setting I can modify to get a more detailed text-based log or if you need me to send a log file from the depth of the data directory, let me know.
