URGENT :Unread Counter Problem
Hi everyone,
I have a problem with unread counter.
It shows 5 unread mails in my inbox.
But I see fewer unread mails than 5
What is the problem ?
Subject: URGENT :Unread Counter Problem
I’m very curious why you consider this to be urgent ???
There are a few possibilities :
  • you deleted a very large number of documents (+ 300 something) and the unread counter is a bit off. You can solve this by setting the 'Remove Documents not modified in the last…" to 0 days . Don’t mark the checkbox, though, because you will loose ALL documents
  • view indexes are not up to date. Update the index by opening the database, and pressing CTRL-SHIFT-F9
cheers,
Tom
Subject: RE: URGENT :Unread Counter Problem
Where do you find the “Remove Documents not modified in the last…”?
Juli
In the replication properties of the database:File/Replication/Settings
