We are in the process of upgrading our servers to 6.5.1 from a 5.x installation. Things are mostly going smoothly, except for a problem with Excel. We export a lot of information into Excel spreadsheets as graphs and reports. We have nice clean installs of Office 2003 on our servers, but we have 2 big problems:
(1) users are now prompted to view a page in the browser that contains the Excel information. This is an additional request for credentials – they have already been prompted and admitted to the application. Once the user re-enters their un/pw they can access the spreadsheet.
(2) code that used to work in 5 no longer works. In this case, we’re formatting a spreadsheet using Excel’s pageSetup class. Any attempt to use a property of that class throws an error and stops the agent from executing. For example:
“Unable to set the TopMargin property of the PageSetup class”
MS’s only answer is that it’s a printing related problem, and they suggest that you check to make sure there’s a good printer setup for the machine. We’ve gone as far as setting up a little HP directly on the server, and it still does not work. We can print easily from the server.
Both of these things worked fine on our R5 servers. We did an upgrade-in-place and haven’t modified any of the server/OS information. It has happened both on our test server and the production server.
Thanks in advance for any clues on this situation.
