Ubuntu 8.04 - Preview Pane problems
The preview pane is giving me problems with the Notes client. I consistently get messages that won’t view in it. I get extra horizontal bars that keep me from viewing the messages. They go away if I shut it down and restart Notes. This does not occur in the 8.0 client on Windows XP.
I also get messages that won’t view when I open them by double-clicking. If you would like to see a sample of this, let me know. I got an email from an IBM guy today that I can’t view at all in the Notes 8.5 beta. It looks fine under 8.0 in Windows.
Subject: This may help
In the Preferences try this option (File->Preferences) under Notes Basic preferences:
“Disable Embedded browser for Mime Mail”
This is likely to be the problem, please confirm. There is another workaround:
If you install this version you should be able to use the internal browser and Sametime:
http://releases.mozilla.org/pub/mozilla.org/xulrunner/releases/1.8.0.1/linux-i686/en-US/
You may also need to set MOZILLA_FIVE_HOME=installed location.
Subject: Worked!
Thanks. Disabling the internal browser for MIME email worked great. Thanks.
