The WEB Navigator retrieval process is not running
This is work for in R5. But in R6 if I call an LotusScript agent that has a getdocumentbyURL from a C API program on a Client machine , I get a “The WEB Navigator retrieval process is not running” error. The same agent works if trigger from R6 client so perweb setting is fine. If the agent is ran from Notes client first to get the WEB Navigator retrieval process loaded, I can call the agent from the C API program without problem. How can I run the Web Nav process from outside of Notes client?
Thanks in advance.
Chet
