Tabbing in Description (Body) field of appointments and to do's
We recently upgraded a client from 7.0.2 FP2 to 8.5.1 and the client noticed an issue with tabbing. When adding notes to the details (body) field of an appointment or to do document, they cannot use tabs to position text. Doesn’t seem to be a problem in the body of the message field.
Anyone know causes? Is this a feature? Can they get their tab functionality back?
Subject: re: Tabbing in Description (Body) field of appointments and to do’s
The Body field on Calendar Entries and ToDos is in a table which is why the normal tab does navigation instead of inserting the text tab but you can use CTRL-Tab instead.
Thanks Jerry. I appreciate the information and workaround. Did not know the ctrl + tab workaround. I had suggested the creation of table or the use of an indented paragraph as a workaround, but the ctrl + tab will be more helpful.
Thanks again,
Ryan
