Hi,When I open a Notes document with IE6 SP2 I get error “…switch from current encoding to specified not supported…”
The document just contain a richtext field with xml content, begining with:
<?xml version="1.0" encoding="UTF-16"?> <?xml-stylesheet type="text/xsl" href="/resources/LCC.xsl"?> ...I initialize the rt field from a stream, running a Java agent:
RichTextItem tmpXML = doc.createRichTextItem(“tmpXML”);
Stream stream = s.createStream();
if ( stream.open(XMLSource,“UTF-16BE”) ) {
tmpXML.appendText(stream.readText());
Does anyone know where is the problem?
Which encoding is being used in rt field?
Note: the same document with IE6 SP1 works fine!!!
Some help will be appreciate.
Thanks,
Sofia.
