I can not get the startup script to run. I am using the standard script that IBM has available in it’s redbook and on the forum. I tried testing it manually first and I can’t even to get it to run that way. I have it loaded in the /etc/init.d directory. I change to that directory and run the “domino stop” command and get a "file not found error. I am absolutly positive the file is there. The name of the script file is “domino”. What can i do here? I’M WEAK IN LINUX!
Thanks!!
