Hi There,
I am trying to insert / update rows in SQL table from a lotus notes database using LSX LC scripts.
Able to connect successfully.
Able to do select query successfully.
Fail to Insert / Update rows in SQL table.
Error is: 12336 - Error: This connection has been dropped, Connector ‘oledb’, Method -Insert-
SQL Server is 10.0.2531
Lotus notes client is 8.5.3 Version .
Using a sql user account I am connecting to SQL database and this user is an owner of the SQL database where trying to insert/update.
src is a connection string, before insert data in a table checked the isconnection property is set as true.
count = src.Insert(FldList,1,1)
Thanks in advance… please help.
Thank you,
Nanda
