Sorting/code page problem
Hey!
I’m quite new to Lotus Notes and I hope you can (and will) help me solve my problem.
Dispite the fact I set the language (and sorting) to ‘Slovenian’ in User preferences/International menu, I can’t seem to find a way to sort the columns correctly- I can use Slovenian letters (like š or ž) but when sorted, they are all displayed after letter Z (and some other signs, like parentheses).
Due to that problem, @DbLookUp functions which I use for retrieving data from “names” directory also don’t work…
Any ideas… ?
Thanks for helping!
Subject: Sorting/code page problem
Try checking the “Accent sensitive sorting” checkbox in the column properties for the column in question.
Morten Steinhauer
PromaSoft AS
Subject: Language sorting?
You might try opening the database properties box, clicking the Design tab, clicking the Multilingual database checkbox, and entering Slovenian in the Default sort order field.
Subject: RE: Language sorting?
THANK YOU!!!
