Hello
I have a question about a parameters in the Smart Upgrdae Kit document, I want to know what happend when choosing the standard configuration vs the basic ?
In reality, the same product can run both configuration, it is just a matter of adding the “-sa” switch on the windows shortcut to start the basic configuration.
But what will happend exactly when doing the Smart Upgrade? Is it the shortcut that is different, is it the product itself (the software installed on the pc) ?
Thansk for your help
