Shift + F9/View rebuild in Lotusscript
Hi All,
May I know how do I write in script to makesure the view is rebuild programmatically, without pressing on the hotkey Shift+F9?
Thanks in advance.
Subject: Open up Domino Designer Help and search for refresh method
It explains the method and includes examples.
For @functions lookup @Command( [ToolsRefreshAllDocs] )
Subject: Embedded view
The problem is, I’m using embedded view. Is there any way to solve this problem?
Subject: refrsh view
after adding document in the embeded view, just call view.refresh and call uidoc.refresh it will solve your problem.thanks
soma
