Hi all,
I have used @setviewinfo in outline elements to filter the docs based on certain criteria. Everything worked well.
The problem is the views which i am showing to the user are direct views meaning not embedded. These views are provided with search bar facility.
So, for normal views if i search, all the docs are shown correctly, but not for filtered docs. If i search for some text in search bar it is showing (15 docs found) but none of the docs are being displayed.
I dont know what is the problem
Please help me on this regard.
–Phani
