Session.ServerName problem
I have a piece of code in a VB Application, which connects to a database to retrieve a view. The problem is that I have the server name hard coded, but wish to change this so that I can create a session, get the name of the server which the session is connecting to, and then use that to connect to a replica of the database with the view.
The code I am using (which works) is this;
Dim session As Object
dim dbIndexer as Object
Set session = CreateObject("Notes.NotesSession")
Set dbIndexer = session.GetDatabase("ServerName", "WPIndex.nsf")
When I try to use the session.ServerName property to retrieve the users server name, I get an error stating that the object does not support the method.
Any ideas ?
Vic
Subject: Session.ServerName problem
just a little thing I see is that you didn’t initialized your session using
session.Initialize
before using any methods or properties. You should initilaze it just after the CreateObject. See exemple in Domino Designer help about ServerName property.
It also says :
This property is null if the session is not running on a server.
Hope it helps
Dave
Subject: RE: Session.ServerName problem
Dave,
Thanks for your reply.
I tried using session.initialise, but I get the same error on this line in my VB program (object doesn’t support property or method)
Is there another way of determininig the users home server from the session ?
vic
I think there’s some misunderstanding here about what the ServerName property is supposed to do.
You referred to the “user’s server name.” There is no “user’s” server in the context of a session object. ServerName is supposed to return the server on which the code is running. If the code runs on a user’s workstation, there is no current server.
You might be thinking of the user’s mail server; in that case you might want to look at OpenMailDatabase method.
In any case, to use methods and properties designated as “COM only,” you definitely need to use Lotus.NotesSession, not Notes.NotesSession, and you do need to call Initialize. Did you try the example in the Designer help?
Andre,
Thanks for your explanation. I was obviously misinterpreting the use of the .ServerName property.
I will try to use the mail database instead, as you have suggested.
Vic
Hi
Try:
Set session As NotesSession
Set session =CreateObject(“Lotus.NotesSession”)
Call session.Initialize
Set dbIndexer = session.GetDatabase(“ServerName”, “WPIndex.nsf”)
regards
Jesper Kiaer
http://www.jezzper.com
Hi Jesper,
Tried this, but with the same error :frowning:
Vic
Subject: This works…
Hi
I have just made a test in VB6 and this works.
Dim Session As New NotesSession
Dim Db As NotesDatabase
Session.Initialize
Set Db = Session.GetDatabase(“servername”, “databasename”)
MsgBox Db.Server, , “ServerName”
There is a bug in Session.ServerName …it returns an empty string, so get the servername from the database object instead
regards
Jesper Kiaer
Subject: RE: This works…
Jesper,
Thanks for this, but to use your code, I will need to specify the server name for the mail database.
What I need to achieve is for the VB app to determine what the users home mail server is so that it can connect to it. I know I can do this by interrogating the notes.ini file, but I would rather not have to do it that way.
Vic
PLEASE see Andre’s response – it’s not a bug.
