Server Error: Entry Not Found In Index ==> Does not always work
Code ==> @DbColumn(“Notes”:“ReCache”;“ef300mmnotes.fishkill.ibm.com”:“300mmProduction.nsf”;“CG1_Monitors”;4)
I am opening the CG1_Monitors View in a frame. I get the error message when the database is first opened. If I switch over to designer, open the view, save the view, go back to Lotus Notes, the @DbColumn function works fine and looks up my values. If I close the database and reopen, the error comes back.
If I open the view via veiw => goto => CG1_Monitors (not opened in the frame), the @DbColumn works fine and looks up my values.
Thank you for your help.
