%REM Sending Meeting Invite or Re-schedule using Lotus Script : Part 2 of 2
Part 2:
Sending Re-Schedule
Part 1 available @
%END REM
'All the variables in Global
Dim session As NotesSession
Dim MailDB As NotesDatabase
Dim currdb As NotesDatabase
Dim dc As NotesDocumentCollection
Dim OutBoxDoc As NotesDocument
Dim MeetingDoc As NotesDocument
Dim StartDTObject As NotesDateTime
Dim EndDTObject As NotesDateTime
Dim StartDate$,StartTime$,EndDate$,EndTime$,StartDateTime$,EndDateTime$
Dim UName$,Topic$,TimeZone$,Location$,SeqNum%
Dim Recipients
Sub Initialize
Set session=New NotesSession
’ Must be same server and db path where the original invite was created
Set MailDB=session.GetDatabase(“ServerName”,“MailDatabasePath”)
Call SetParameters
Call CreateMeetingDoc
Call SetParameters
Call CreateOutBoxDoc
Sub SetParameters
StartDate$="21-Apr-2014"
StartTime$="11:00"
EndDate$="21-Apr-2014"
EndTime$="12:00"
StartDateTime$=StartDate$+" "+StartTime$
EndDateTime$=EndDate$+" "+EndTime$
Set StartDTObject = New NotesDateTime(StartDateTime$)
Set EndDTObject = New NotesDateTime(EndDateTime$)
Topic$="Domino Solutions : Updated Version"
UName$="SENDER NAME" ' Notes Name or any name whose mail box is on the server
'comma separated names
Recipients=Split("Lotus Notes Canonical or abbreviated format, xyz@abc.com, somename@gmail.com",",")
Location$="New York"
Sub CreateMeetingDoc
Set MeetingDoc=MailDB.GetDocumentByUNID("STRINGFORMAT OF THE ORIGINAL/FIRST MEETING DOCUMENT UNID")
MeetingDoc.Form="Appointment" 'IMPORTANT
MeetingDoc.Subject=Topic$
Call MeetingDoc.ReplaceItemValue("StartDateTime",StartDTObject)
Call MeetingDoc.ReplaceItemValue("CalendarDateTime",StartDTObject)
Call StartDTObject.SetAnyTime 'It will set only Date (not time)
Call MeetingDoc.ReplaceItemValue("StartDate",StartDTObject)
Set StartDTObject= New NotesDateTime(StartDateTime$)
Call StartDTObject.SetAnyDate 'It will set only Time (not date
Call MeetingDoc.ReplaceItemValue("StartTime",StartDTObject)
Set EndDTObject= New NotesDateTime(EndDateTime$)
Call MeetingDoc.ReplaceItemValue("EndDateTime",EndDTObject)
Call EndDTObject.SetAnyTime 'It will set only Date (not time)
Call MeetingDoc.ReplaceItemValue("EndDate",EndDTObject)
Call EndDTObject.SetAnyDate 'It will set only Time (not date)
Call MeetingDoc.ReplaceItemValue("EndTime",EndDTObject)
Call MeetingDoc.ReplaceItemValue("$NoPurge",EndDTObject)
Call MeetingDoc.Replaceitemvalue("AppointmentType","3") 'IMPORTANT
Call MeetingDoc.RemoveItem("NoticeType")
'FOLLOWING TWO LINES ARE VERY VERY IMPORTANT
SeqNum%=MeetingDoc.GetItemValue("SequenceNum")(0) 'VERY VERY IMPORTANT
Call MeetingDoc.Replaceitemvalue("SequenceNum",SeqNum%+1) 'VERY VERY IMPORTANT
Call MeetingDoc.ReplaceItemValue("$CSVersion","2") 'IMP
Call MeetingDoc.Replaceitemvalue("$PublicAccess","1") 'IMP
Call MeetingDoc.Replaceitemvalue("_ViewIcon",158) 'REQUIRED TO DISPLAY APPROPRIATE ICON
Call MeetingDoc.Replaceitemvalue("Recipients",Recipients)
Call MeetingDoc.Replaceitemvalue("Chair",UName$)
Call MeetingDoc.Replaceitemvalue("From",UName$)
Call MeetingDoc.Replaceitemvalue("Principal",UName$)
Call MeetingDoc.Replaceitemvalue("ApptUNID",MeetingDoc.UniversalID) 'THIS ENSURES THAT THE APPUNID HAS NOT CHANGED
Call MeetingDoc.Replaceitemvalue("Location",Location$)
Call MeetingDoc.Replaceitemvalue("RequiredAttendees",Recipients)
Call MeetingDoc.Save(1,0)
Sub CreateOutBoxDoc
Set OutBoxDoc=MailDB.CreateDocument
OutBoxDoc.Form="Notice"
OutBoxDoc.Subject="Rescheduled: "+Topic$+" "+"( "+StartDateTime$+" in "+Location$+")"
OutBoxDoc.SendTo=Recipients
OutBoxDoc.Topic=Topic$
Call OutBoxDoc.ReplaceItemValue("StartDateTime",StartDTObject)
'THE "CalendarDateTime" FIELD NOT REQUIRED WHILE MAILING
' NOT REQUIRED Call OutBoxDoc.ReplaceItemValue("CalendarDateTime",StartDTObject)
Call OutBoxDoc.ReplaceItemValue("StartDate",StartDTObject)
Call StartDTObject.SetAnyDate 'It will set only Time (not date)
Call OutBoxDoc.ReplaceItemValue("StartTime",StartDTObject)
Call OutBoxDoc.ReplaceItemValue("EndDateTime",EndDTObject)
Call OutBoxDoc.ReplaceItemValue("EndDate",EndDTObject)
Call OutBoxDoc.ReplaceItemValue("EndTime",EndDTObject)
Call OutBoxDoc.ReplaceItemValue("$CSFlags","w") 'IMPORTANT
Call OutBoxDoc.ReplaceItemValue("$NoPurge",EndDTObject)
Call OutBoxDoc.MakeResponse(MeetingDoc)
Call OutBoxDoc.ReplaceItemValue("$REFOptions","1")
Call OutBoxDoc.Replaceitemvalue("AppointmentType","3") 'IMPORTANT
Call OutBoxDoc.Replaceitemvalue("NoticeType","U") 'IMPORTANT-INDICATES RE-SCHEDULE
Call OutBoxDoc.ReplaceItemValue("$CSVersion","2") 'IMPORTANT
Call OutBoxDoc.Replaceitemvalue("$PublicAccess","1") 'IMPORTANT
Call OutBoxDoc.Replaceitemvalue("SequenceNum",MeetingDoc.SequenceNum(0)) 'VERY VERY IMPORTANT
Call OutBoxDoc.Replaceitemvalue("_ViewIcon",33) 'APPROPRIATE ICON
Call OutBoxDoc.Replaceitemvalue("Recipients",Recipients)
Call OutBoxDoc.Replaceitemvalue("Chair",UName$)
Call OutBoxDoc.Replaceitemvalue("From",UName$)
Call OutBoxDoc.Replaceitemvalue("Principal",UName$)
Call OutBoxDoc.Replaceitemvalue("ApptUNID",MeetingDoc.UniversalID) 'IMPORTANT
Call OutBoxDoc.Replaceitemvalue("RequiredAttendees",Recipients)
Call OutBoxDoc.Replaceitemvalue("Location",Location$)
Call OutBoxDoc.Replaceitemvalue("UpdateSeq",1)
Call OutBoxDoc.Replaceitemvalue("PostedDate",Now)
Call OutBoxDoc.Replaceitemvalue("OriginalModTime",Now)'Modification Time
Call OutBoxDoc.MakeResponse(MeetingDoc) 'VERY VERY IMPORTANT
Call OutBoxDoc.ReplaceItemValue("$REFOptions","1") 'VERY VERY IMPORTANT
Call OutBoxDoc.Send(0)
