Hi
Can anyone help me please?
When I prompt for a start date from the input box & user selects cancel, I want it to not loop back in.
Same problem occurs with the end date prompt.
Hope someone can help?.
Sub Click(Source As Button)
Dim ws As New notesuiworkspace
Dim db As NotesDatabase
Dim doc As NotesDocument
Dim view As NotesView
Dim vc As NotesViewEntryCollection
Dim coll As notesdocumentcollection
Dim ndt As New NotesDateTime("01/01/1900")
Set view = db.GetView("LocSearch")
Set vc = view.AllEntries
If vc.count > 0 Then
response = Messagebox("Starting a new search will remove the results from the previous search."+Chr(10)+_
"Do you wish to continue?",36,"Location Search")
If response = 6 Then 'Yes
Print "Marriages Location Search - Removing previous search results..."
Call vc.RemoveAllFromFolder( "LocSearch" )
If response = 7 Then 'No
Continue = False
’ Set view = db.GetView(“DO”)
no1:
response = Inputbox("Please enter the start date of your search. Please enter the format of DD/MM/YYYY","Location Search")
’ response2 = Cdat(Format(response,“dd/mm/yyyy”))
If Not (response Like "##/##/####") Then
Msgbox "Date must be in the format of DD/MM/YYYY",16,"Stop"
Goto no1
'If response = 2 Then 'No
' Continue = False
'End If
no2:
endresponse = Inputbox ("Please enter the end date of your search. Please enter the format of DD/MM/YYYY", "Location Search")
'endresponse2 = Cdat(Format(endresponse,“dd/mm/yyyy”))
If Not (endresponse Like "##/##/####") Then
Goto no2
xForm = | Form = "regform" & dateopened >=@TextToTime("| & (response) & |") & dateopened <= @TextToTime ("| &( endresponse )& |") & dateopened!= ""|
'Confirmation of archive
areyousure = Messagebox("Are you sure you wish to search between the dates of " + Cstr(response) + " to " + Cstr(endresponse), 36, "Location Search")
If areyousure = 7 Then 'No
Messagebox "Searching for monthly figures report cancelled.", 64, "Location Search"
Exit Sub
'Get All documents with that year
Print "Please wait while the system finds all of the cases..."
Set coll=db.Search(xForm,ndt,0)
If coll.count = 0 Then ' amended to coll TB
Messagebox "The system has found no cases matching dates between"+ Cstr(response) + " and " + Cstr(endresponse), 64, "Location Search"
Exit Sub
'Copy to folder
Call coll.PutAllInFolder( "LocSearch" ) ' amended to coll TB
Print "Searching complete - please wait while the view is refreshed ... (this can take upto 30 minutes)"
'Refresh view at end (This can take a while if a large number of documents have been moved)
Call ws.viewrefresh
Print "Searching complete - thank you for waiting"
If coll.count > 0 Then
Messagebox "The system found "+ Cstr(coll.count) +" cases ""."+_
Chr(10)+" .",64,"Location Search"
