Screenshots in Body of Memo
Is there any way to programmatically detect (via LotusScript or Formula) when there is an ordinary screenshot that has been pasted within the Body of a memo?
I am currently already using the “HasEmbedded” document property for detecting valid attachments. Thanks ahead of time.
Subject: Screenshots in Body of Memo
Function hasGraphic( ) As Boolean’ finds out whether the current document (open on screen) contains a graphic in a rich text field.
Dim wksp As New NotesUIWorkspace
Dim uidoc As NotesUIDocument
Dim doc As NotesDocument
Dim rti As NotesRichTextItem
Set uidoc = wksp.CurrentDocument
If uidoc.EditMode Then Call uidoc.Refresh(True)
Set doc = uidoc.Document
Dim dxlx As NotesDXLExporter
Set dxlx = session.CreateDXLExporter( )
Dim strOut As String
strOut = dxlx.Export(doc)
hasGraphic = Instr(strOut, “<picture”) > 0
End Function
It is possible to export to DXL and check that for the appropriate tags. A bit of work, but it would detect anything you liked.
Thank you both, Ben & Betsy, so much for your help. I greatly appreciate it.
