My 6.0.2 Domino server on iSeries is spiking 99% processor utilization. The culprit seems to be ScanMail PSCAN.
TrendMicro says that applying the 2.6 patch “build 1644” will alleviate the problem.
Anyone have similar problems or experience with this new patch? Any problems after applying the patch? Does it alleviate the original problem?
Your replies are very much appreciated.
Subject: We haven’t had any problems
We have been running build 1644 for a couple of months without any problems. We previously used Symantec’s A/V filtering for Domino, and our initial install of ScanMail was build 1644.
The server’s operating system is V5R2, and the Domino version is 6.5.2
Subject: ScanMail build 1644 - Problems with iSeries Domino?
We had a similar problem which ‘appeared’ (was never confirmed) to cause server instability and high CPU utilization.
The issue escalated after upgrading to 6.5.4 afterwhich PUPDATE would not obtain any new definitions. Also, the engine was still at 7.000 instead of the current 7.510.
After applying the patch, server was stable, and PUPDATE obtained both the engine and the patch without any manual intervention.
As a precaution, I always backup the ScanMail configuration file incase of any mishaps as I’ve noticed that any major releases of ScanMail overwrite the file entirely. The patch did not affect it however.
The installation of the patch was fairly simple.
