Sametime Version: 12.0.3
Operating System: Linux
Problem/Query:
Hello,
if i check the system requirements for Sametime 12.0.3, the supported version for docker engine is 25.0, 26.0 and 27.0.
If i check the docker website these versions are EOL
Because Sametime 12.0.4 is not released yet, is there a plan to support Docker engine higher than 27.0.x for Sametime 12.0.3 ?
