After installing the new sametime 11.5 proxy, the sametime client inside iNotes is not working anymore because an X-Frame-Options is set to SAMEORIGIN on the stproxy.
In fact the tomcat security behavior has changed since this sametime version. Now the httpHeaderSecurity is enabled by default (set in the /conf/web.xml)
Commenting all the lines relatives to httpHeaderSecurity solves the issue.
However, It would be better to not disable the default security and to only allow the mail server to pass this security feature.
I am not familiar with tomcat. So does anyone know how to refine the tomcat config to do that?
We updated 11.5 to include the X-Frame-options header with SAMEORIGIN set. This was done to tighten the default security model.
If you wish to allow Verse or other integrations with the Sametime Proxy to work, you will need to modify the following section of the conf/web.xml file
<init-param>
<param-name>antiClickJackingOption</param-name>
<param-value>SAMEORIGIN</param-value>
</init-param>
to
<init-param>
<param-value>ALLOW-FROM</param-value>
</init-param>
<init-param>
<param-name>antiClickJackingUri</param-name>
<param-value>https://*.company.com</param-value>
</init-param>
or disable the header entirely by changing it to
<init-param>
<param-name>antiClickJackingEnabled</param-name>
<param-value>false</param-value>
</init-param>
And then restart the Sametime Proxy Server.
As always, its suggested you back up the web.xml file before making any changes.
Thank you Anthony. I've tested and it works fine.
Hello Anthony,
with your information the integration with INotes/Verse will work again (if using ST Proxy V11.5). Could you please update the Sametime documentation about this ?
Thank you
