I wrote an agent that’s supposed to open a database plus a view and deal with the documents in that view. My aim is to to have each document opened in adit mode, save a certain field and close the document for all the documents in that view.
why? Coz I figured this way, if I have say a document with a field “Body” that is in mime format and the document is opened followed by one or two changes, the saved document will have this body field changed from mime to a rti. Then I can be able to manipulate it using the normal richtext class functions without losing the fonts etc.
Now the question is can you have a agent that runs this kind of a scenerio having a workspace opened and document opened and saved etc. The on event one works fine but I then need this agent to run without human interaction.
MY AGENT AS IT STANDS:
Sub Initialize
Dim uidoc As NotesUIDocument
Dim doc As NotesDocument
Dim uiview As NotesUIView
Dim server As String
Dim dbase As String
Dim view As NotesView
Dim agentLog As New NotesLog("Agent log")
Call agentLog.OpenAgentLog
server=""
dbase="eDividePart2/eDivideUvimba.nsf"
Call agentLog.LogAction("Opening the database...")
Call workspace.OpenDatabase(server,dbase,"processedInbound","",False,False)
Set uiview = workspace.CurrentView
Set view = uiview.View
'Messagebox view.EntryCount
count = view.EntryCount
Call agentLog.LogAction("Found " + count + " documents.")
While count >= 1
Set doc = view.GetNthDocument(count)
If Not(doc Is Nothing) Then
Call agentLog.LogAction("Processing document...")
Call workspace.EditDocument(True,doc)
count = count - 1
Wend
Call agentLog.Close
'Call uiview.Close
after the scheduled time, my log file says the agent has run successfully but it’s not printing the information about the agentLog. Any ideas please help.
jay
