The documentation of the core image documents that we can run the core image on Docker only (https://help.hcltechsw.com/digital-experience/9.5/containerization/cw_containerdbtransfer_ibm_db2.html). I.e. we don't need a K8S based plattform to run it. However I couldn't find any documentation for the other images (experience APIs, DAM etc.).
Could get the experience API container up and running using:
podman run -d --name hclringapi -p 3000:3000 -e PORTAL_HOST=hhuelinux.hhue.at -e PORTAL_PORT=10039 -e PORTAL_SSL_ENABLED=false -e CORS_ORIGIN='*' --security-opt label=disable localhost/hcl/dx/ringapi:v1.2.0_20200819-1139
podman logs -f $(podman ps -f name=hclringapi --format=“{{.ID}}”)
So that I could access the following URLs:
- http://localhost:3000/dx/api/core/v1/graphql
However what I'm missing is the connection to WCM etc.
Therefore I'm wondering if the documentation could be enhanced to run all the images on a dev. workstation without needinf a K8s based environment? That would be of great help ...
