Routing problem to gmail and yahoo------------------------------------------------------
All my mail is routing correctly except for routing mails to GMAIL.COM
Log message:
Router: No messages transferred to GMAIL.COM (host gmail-smtp-in.l.google.COM) via SMTP.
I have not static IP.
I am using an free dns service www.cdmon.com
My OS is Windows XP
My Lotus is 6.5.3
My database email is on the server.
My configuration wrong ?
My Log.nsf tell me the following
25/08/2008 10:23:30 p.m. [11F4:0008-16C0] SMTPClient: Attempting to Connect: Host gmail-smtp-in.l.google.COM, Port 25, SSL Port 0, Connecting Domain bellina.cdmon.org
25/08/2008 10:23:30 p.m. [11F4:0008-16C0] SMTPClient: Connection successful
25/08/2008 10:23:30 p.m. [11F4:0008-16C0] SMTPClient: ReceiveResponse: 220 mx.google.com ESMTP 9si7259408ywf.2
25/08/2008 10:23:30 p.m. [11F4:0008-16C0] SMTPClient: CommandEHLO: EHLO bellina.cdmon.org
25/08/2008 10:23:30 p.m. [11F4:0008-16C0] SMTPClient: ReceiveResponse: 250-mx.google.com at your service, [201.231.140.42]
25/08/2008 10:23:30 p.m. [11F4:0008-16C0] SMTPClient: ReceiveResponse: 250-SIZE 28311552
25/08/2008 10:23:30 p.m. [11F4:0008-16C0] SMTPClient: ReceiveResponse: 250-8BITMIME
25/08/2008 10:23:30 p.m. [11F4:0008-16C0] SMTPClient: ReceiveResponse: 250 ENHANCEDSTATUSCODES
25/08/2008 10:23:30 p.m. [11F4:0008-16C0] SMTPClient: Attempting to SubmitMessage:
25/08/2008 10:23:30 p.m. [11F4:0008-16C0] SMTPClient: CommandMAIL: MAIL FROM:jmbellina@bellina.com.ar SIZE=2146
25/08/2008 10:23:31 p.m. [11F4:0008-16C0] SMTPClient: ReceiveResponse: 250 2.1.0 OK
25/08/2008 10:23:31 p.m. [11F4:0008-16C0] SMTPClient: CommandRCPT: RCPT TO:jmbellina@gmail.com
25/08/2008 10:23:35 p.m. [11F4:0008-16C0] SMTPClient: ReceiveResponse: 250 2.1.5 OK
25/08/2008 10:23:35 p.m. [11F4:0008-16C0] SMTPClient: CommandDATA: DATA
25/08/2008 10:23:35 p.m. [11F4:0008-16C0] SMTPClient: ReceiveResponse: 354 Go ahead
25/08/2008 10:23:35 p.m. [11F4:0008-16C0] SMTPClient: Data Send Succeeded 855 bytes
25/08/2008 10:23:36 p.m. [11F4:0008-16C0] SMTPClient: ReceiveResponse: 550-5.7.1 [201.231.140.42] The IP you’re using to send mail is not authorized
25/08/2008 10:23:36 p.m. [11F4:0008-16C0] SMTPClient: ReceiveResponse: 550-5.7.1 to send email directly to our servers. Please use the SMTP
25/08/2008 10:23:36 p.m. [11F4:0008-16C0] SMTPClient: ReceiveResponse: 550-5.7.1 relay at your service provider instead. Learn more at
25/08/2008 10:23:36 p.m. [11F4:0008-16C0] SMTPClient: ReceiveResponse: 550 5.7.1 'The IP you're using to send email is not authorized...' - Gmail Help 9si7259408ywf.2
25/08/2008 10:23:36 p.m. [11F4:0008-16C0] SMTPClient: CommandRSET:
25/08/2008 10:23:36 p.m. [11F4:0008-16C0] SMTPClient: ReceiveResponse: 250 2.1.0 Flushed 9si7259408ywf.2
25/08/2008 10:23:36 p.m. [11F4:0008-16C0] SMTPClient: Attempting to Disconnect:
25/08/2008 10:23:36 p.m. [11F4:0008-16C0] SMTPClient: CommandQUIT:
25/08/2008 10:23:36 p.m. [11F4:0008-16C0] SMTPClient: ReceiveResponse: 221 2.0.0 mx.google.com closing connection 9si7259408ywf.2
25/08/2008 10:23:36 p.m. [11F4:0008-16C0] SMTPClient: Connection terminated successfully
25/08/2008 10:23:36 p.m. Router: No messages transferred to GMAIL.COM (host gmail-smtp-in.l.google.COM) via SMTP
