Rich Text Field Problem in View
I have a Rich Text field called “COMMENT” … i used @Text(Comment) in a view formula… nothing shows.
I then made a computed field in the form … with the same formula… and the data is there ok…
I then put the name of the computed field in the view… and nothing shows up…even though it does show up in the form when I look it there.
Any ideas??
Subject: Rich Text Field Problem in View
Rich Text fields don’t show up in views if you just put the field name in it. Look in the help at @abstract. See if that will help you get what you want into the view column.
