I have recently set up an archive db, I selected a document from a folder to archive and the doc was archived successfully. I tried to bring it back and these messages appeared:Duplicate PUBLIC name CMEMOBJECT in USE for module CoreEmailClasses
when I hit ok then:
Not a sub or function name: MARMESSAGEFORFOLLOWUP
I hit ok and the msg appears 4 more times, then:
Class or type not found: JUNKRULES
I hit ok again, the doc appears and this msg:
Variable not declared: TIMEVALIDATEARGSEXT
I hit ok and the msg appears again, then I close the doc and the msg appears 1 more time then closes…
Anybody experienced this by chance, or does anybody have an idea of how to fix this…thanks, this is my first venture into archiving…so far, not good…
Hi Timothy, I did a clean install with the notes 6.5 client and it worked like a charm. (Uninstall the client, rename the lotus folder in lotus.old for example, and then install the client again).
