hiisn’t Field $REF enough criteria for parent-response relationship??
In all hierarchical views of our database only some response documents show up but
ALL have the same value in the $REF field.
I could restore by Makeresponse but there are over 8000 responses for one document.
So another question:
Is there a Maximum Number for Responses for One Document?
Please Help
Heinrich Mueller
first posting see here:
http://www-10.lotus.com/ldd/nd6forum.nsf/55c38d716d632d9b8525689b005ba1c0/596b0db518dd48f585257042003e9afe?OpenDocument
Subject: repost: need help with $ref and parent-reponse relationsship
I don’t know about response limitations, but modifying 6000 documents with makeresponse shouldn’t take long on reasonably recent hardware.
Subject: RE: repost: need help with $ref and parent-reponse relationsship
Thanks a lot Peter, I see there is no other workaround (may be Fixup?) but it seems a little bit mysterious
