I have created a group with several servers using a single connection document. But the replication between the servers is not happening frequently? what is the solution for this?
Subject: replicaton problem
Have you had a look at the replication view of the log on the server that initiates the replication for any errors?
Your Server Connection Document controls the replication. What is it set to?
HTH.
Gregg
Subject: Right; what does “not happening frequently” mean?
