Replication problem
I have a problem with database replication, automatic replication is not working any more, every time I try to start replication manually I get the following message “Background replication request (1,2,…) of (1,2,…) in queue”
any ideas?
Subject: Replication problem
Try this thread.
http://www-10.lotus.com/ldd/nd6forum.nsf/55c38d716d632d9b8525689b005ba1c0/b39ec399ae6d1db7852571af00425a8c?OpenDocument
Shawn
When replication stops working the first thing I do is clear the Replication History in both databases. This significantly increases the amount of time the next replication takes becasue it has to rebuild the Replication Table. However, I have found that it almost always fixes the problem.
Subject: RE: Replication problem
Hey thanx guys, clearing the Replication History solved the problem.
