Replacing Chr(10) and Chr(13) using script
I have a file attachment which consists of 2 lines.
e.g.
First word, First line
First word, Second line
I am trying to append something to both lines by using:
Print #fileNum, tempString(0)+ |,“myappendstring”|
The result that i’m looking for is:
First word, First line, myappendstring
First word, Second line, myappendstring
However because there seems to be a carriage return at the end of each line, the ‘myappendstring’ is appearing on the next line.
I suppose i’ll need to somehow replace the Chr(10) and Chr(13) with blanks before appending the string.
How can i get rid of the Chr(10) and Chr(13) using lotus script?
Subject: Replacing Chr(10) and Chr(13) using script
It may be easier if you read the file without including the newline characters. To do this, use the “Line Input #” command. This will read a line from the text file, and stop when it finds a newline character.
Hope this helps,
Craig.
Here’s a thing I wrote that takes Chr(10) and Chr(13) out of strings…you can modify it to do what you need…the For/Next loop is what you want
Sub Querysave(Source As Notesuidocument, Continue As Variant)
 Dim workspace                  As New notesuiworkspace
 Dim Doc                               As NotesDocument
 Dim strConverted               As String
 Dim strConverted2             As String
 Dim i                                       As Integer
 Dim TextString                    As String
 Dim TextString2                  As String
 Set uidoc                               = workspace.currentdocument
 Set doc                                  = uidoc.document
 TextString                             = doc.description(0)
 TextString2                           = doc.MinQual(0)
 For i = 1 To Len(TextString)
      If Asc(Mid(TextString,i,1)) = Clng(13) Or Asc(Mid(TextString,i,1)) = Clng(10) Then
           strConverted = strConverted + Space(1)
      Else
           strConverted = strConverted + Mid(TextString,i,1)
 Next
 For i = 1 To Len(TextString2)
      If Asc(Mid(TextString2,i,1)) = Clng(13) Or Asc(Mid(TextString2,i,1)) = Clng(10) Then
           strConverted2 = strConverted2 + Space(1)
      Else
           strConverted2 = strConverted2 + Mid(TextString2,i,1)
 Next
 If  (Doc.HasItem("NoReturn")) Then
      Call Doc.RemoveItem("NoReturn")
 If  (Doc.HasItem("Thursday")) Then
      Call Doc.RemoveItem("Thursday")
 If  (Doc.HasItem("NoReturn2")) Then
      Call Doc.RemoveItem("NoReturn2")
 Call doc.AppendItemValue("NoReturn", strConverted)
 Call doc.AppendItemValue("NoReturn2" , strConverted2)
Subject: RE: Replacing Chr(10) and Chr(13) using script
Steven - Many thanks for you “stripper”
